Thread: Quattro transmission slack?
Results 1 to 8 of 8
  1. Quattro transmission slack?
    Ardfern
    8 Post(s)
    My other half’s quattro avant is getting a little long in the tooth with 214k miles but goes well. An annoying characteristic is that at slow speeds when dribbling along it seems to stutter as if not sure whether to pull or not. I first thought it might be a throttle issue but since it pulls like a train whenever asked, I am wondering if this might be caused by some transmission slackness perhaps in a UJ in a drive shaft or something similar.
    Has anyone experienced this sort of problem and can suggest what may be at fault?
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  2. Re: Quattro transmission slack?
    1836 Post(s)
    At that mileage there certainly could be some lash in various components so up in the air for a check BUT on a two post the and doe of the joints due to suspension drop can hide problems; I have even known the problem to go away after being in the air as the extra articulation has moved grease into dry areas.
  3. Re: Quattro transmission slack?
    Ardfern
    8 Post(s)
    Thanks. I’ll try some investigation.
    Lotus Elan SE 1991
  4. Re: Quattro transmission slack?
    Ardfern
    8 Post(s)
    I had the chance to have it looked at on a lift by an MOT tester locally who also drove it. No transmission slack found at all. So what’s next? Something to do with the throttle at low revs? Any suggestions where to start? Might there be something which has become gummed up and needs a clean?
    Lotus Elan SE 1991
  5. Re: Quattro transmission slack?
    1836 Post(s)
    Which engine is it and manual?
  6. Re: Quattro transmission slack?
    Ardfern
    8 Post(s)
    It’s a 2.0 tdi 170 with manual box.
    Lotus Elan SE 1991
  7. Re: Quattro transmission slack?
    1836 Post(s)
    You could start with a code read to see if there is anything amiss, for example an electro hydraulic engine mount failure which is common.
  8. Re: Quattro transmission slack?
    Ardfern
    8 Post(s)
    Thanks. I’ll check but don’t think any engine mount faults showed on a fairly recent vcds. scan.
    Lotus Elan SE 1991
  1. GEARSHIFT CABLES ADJUSTMENT/Slack
    By mlm@btinternet in forum Golf MK4 - 1999 - 2004
    Last Post: 18-04-2017, 08:22 PM
  2. Please Help Transmission rumble from 3.0 TDI Quattro
    By boycie in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-08-2010, 09:21 PM
  3. 4.2 quattro engine or transmission?
    By bgdk52 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-06-2010, 12:55 PM
  4. Please Help A4 2.5 TDi Quattro Transmission problem
    By Keebs in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-06-2009, 11:54 PM
  5. Please Help audi a4 slack in gear lever - help
    By scotchydoodle in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2009, 11:22 PM
