Thread: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
Results 1 to 10 of 16
  1. Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Hi got the follow error codes after an autoscan with VCDS.
    There seems to be a problem with the accelerator position sensor, EPC light is coming on and car goes into limp home mode, code tends to go when car is stopped and ignition on and
    off again.
    Also got an issue with a rear brake bulb on central electrics module and electrical issue on ABS brakes module.
    P1633 - 002 - Signal too Low
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    00988 - Lamp for Brake Light; Right (M10)
    Let me know who to resolve this issues if anyone has any experience with these codes.
    Code:
    Saturday,22,January,2022,11:13:29:33544
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 21.9.0.2 (x64)
    Data version: 20210903 DS330.0
    www.Ross-Tech.com
    VIN: WVWZZZ1KZ4W096975   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WVWZZZ1KZ4W096975   Mileage: 376620km-234020miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 906 056 BA    HW: Hardware No
       Component: MED9.5.10       G00 5697
       Revision: 00000000    Serial number: VWZ7Z0D9331576
       Coding: 0000072
       Shop #: WSC 01279 785 00200
       VCID: 63C1C201A2D6B0913C-8036
       VINID: 9E69EAAAA05BA849C024624714EDDC82ED
    1 Fault Found:
    Readiness: 0000 0000
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0019073
       VCID: 3A7F5F6575DC91594F-806E
    1 Fault Found:
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No SW: 1K0 820 047 FT    HW: 1K0 820 047 FT
       Component: Climatic PQ35   141 0909
       Revision: 00141027    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 7BF19A613A66685114-802E
    No fault code found.
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
       Component: Bordnetz-SG 1.0 H30 0701
       Revision: 00030000    Serial number: 00000000514812
       Coding: E48D0F0600041800001400001400000000
       VCID: 3779465146CE8C31B0-8062
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Shop #: WSC 00000
       Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 002  0505
       Coding: 00217125
       Shop #: WSC 00000
    1 Fault Found:
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
       Component: 0M AIRBAG VW8   022 0500
       Revision: 04022000    Serial number: 0033FD08P0VC
       Coding: 0012365
       Shop #: WSC 01268 785 00200
       VCID: 2A5F6F25857C21D93F-807E
       Subsystem 1 - Serial number: 6332MSME5D7E1002
       Subsystem 2 - Serial number: 6342MSME57340A02
       Subsystem 3 - Serial number: 6351HSME43485801
       Subsystem 4 - Serial number: 6361HSME5D0F5901
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 012 0030
       Coding: 0000022
       VCID: 306B7D4DA3A05B09F1-8064
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No: 1K0 920 950 K
       Component: KOMBIINSTRUMENT VDD 3554
       Coding: 0000401
       Shop #: WSC 00218 210 03908
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2100104128EF35
       Coding: 3D0F0340070003
       VCID: 27599611966E1CB120-8072
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO                3554
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0116
       Coding: 0000052
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
       Part No: 1K2 909 144 E
       Component: EPS_ZFLS Kl.1       1202
       VCID: 2E576335B9944DF9E3-807A
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 81E802087F2D8505485BC61000
       Shop #: WSC 00218 210 08203
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Subsystem 3 - Part No: 1K0 951 177
       Component: Innenraumueberw.004 0101
    1 Fault Found:
    01134 - Alarm Horn (H12)
                004 - No Signal/Communication
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       VCID: 316D7849A8AA5201FE-8064
    Address 56: Radio        Labels: 1K0-035-1xx-56.clb
       Part No: 1K0 035 186 J
       Component: Radio BNO           0016
       Coding: 0040400
       VCID: 2D556439B49236E1DA-8078
    End-------------------------(Elapsed Time: 01:36)--------------------------
  2. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    1840 Post(s)
    If you keep getting the G185 error, fit the new revised from 2010 pedal 1K2 721 503 AJ it is a five minute job but £148.61, the Hella 6PV 011 040-711 is a third of this. The voltage issue is pretty obvious but your early cable is letting you down here by not showing the voltage. Check the correct bulb is fitted, often we see single filament 382 bulbs used where a twin filament 380 should be used.
  3. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    Jul 2018
    8 Post(s)
    Thanks Crasher.
    What cable should I be upgrading to for VCDS? I guess there will be a charge for this from Ross Tech?
    If I had the newer cable I would be able to see the voltages?
    Should I just get another pedal or should I check first with upgraded VCDS?
    I shall double check what bulb I have fitted. So for the brake light it should be twin filament 382?
    Thank you
  4. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    1840 Post(s)
    The HEX NET interface shows the start and finish voltages on suitable cars at the end of the scan and lots of ROD data, someone like you needs to set themselves up with the HEX-NET pro, I get mine from Home - Marshalls Industrial
  5. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    Jul 2018
    8 Post(s)
    Thanks for the information I shall look at upgrade / purchase new cable.
    In mean time I’ve now got the CEL on now so need to do
    another scan and post here
    Should I be checking the wiring from the pedal to ECU (prior to buying a replacement throttle pedal?). Think I’ve got the wiring diagram you sent me a while back when I had an issue with the wiring from the throttle body to the ECU.
    Hopefully the overlay harness I did from the 6 pin connector from the throttle body to the Ecu plug isn’t causing an issue or has failed also?
  6. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    Mar 2010
    Derry ireland
    60 Post(s)
    Can you post up your engine code or reg no
  7. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    Jul 2018
    8 Post(s)
    It’s a BAG engine code. 1K chassis.
  8. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    Jul 2018
    8 Post(s)
    Now getting this code......same number 18041 but intermittent now....
    This still meaning the throttle pedal is failing / needs replacing?
    I did check measuring blocks and all the values for pedal position and throttle all look stable and ok.....
    Can't see any values jumping around? Just trying to understand where the computer is picking up the fault from?
    Did have EPC and CEL on, now just got the CEL.....
    P1633 - 002 - Signal too Low - Intermittent - MIL ON
    Code:
    Monday,24,January,2022,19:03:04:33544
    www.Ross-Tech.com
    VIN: WVWZZZ1KZ4W096975   Mileage: 376660km-234045miles
       Coding: 0000072
    1 Fault Found:
    Readiness: 0010 0001
       Coding: 0019073
       Coding: 00065493
       Shop #: WSC 00000
       Coding: 00217125
       Shop #: WSC 00000
       Coding: 0012365
       Coding: 0000022
       Coding: 0000401
       Coding: 0000052
    1 Fault Found:
       Coding: 0000052
       Part No: 5M0 035 186 B
       Component: Radio GR0       019 0023
       Revision: 0001905S    Serial number: VWZ2Z2F1081507
       Coding: 0040401
       Shop #: WSC 01392 785 00200
       VCID: 2B516A218A8638D1C4-807E
    End-------------------------(Elapsed Time: 01:32)--------------------------
  9. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    Mar 2010
    Derry ireland
    60 Post(s)
    The pedal sensor on your engine car works on 2 track system thats why their is 2 earths. 2x 5v feeds & 2 return wires to the ecu. Check pedal with plug disconnected ign on you should have 2 5v feeds at terminals 1 & 2. the 2 earths terminals are 3 & 5. The 2 signal return wires to the ecu are 4 & 6.I will post you up the corresponding ecu pin nos & wire colours later if required
  10. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    Jul 2018
    8 Post(s)
    Thanks @mickeybo I’ll wait for you reply.
    Ive attached what I think is the correct wiring diagram but my German isn’t the best. I think the accelerator pedal to Ecu is shown on the bottom left hand corner.
  1. Wanted 1998 Audi S4 Accelerator position sensor **wanted**
    By Jon.burr in forum Parts & Accessory Price Requests
    Last Post: 21-05-2021, 03:20 PM
  2. 18047 - Accelerator Position Sensor 1/2 (G79/G185) and 01314 - Engine Control Module
    By ianlovatt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-12-2020, 11:35 PM
  3. anybody know wher the audi a3 tdi 2004 accelerator position sensor is
    By lance h in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-07-2012, 03:34 PM
  4. Please Help passat accelerator position sensor
    By flockton in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-09-2010, 04:02 PM
  5. accelerator pedal position sensor
    By 4udi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-03-2008, 01:45 PM
