Thread: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Will the following part number 1K2 723 503 T be compatible?
  2. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    133 Post(s)
    1988 Post(s)
    So you mean a used 1K2 723 503 T? This changed to 1K2 723 503 AE in 2011 and AJ in 2012 so yes it would work but as it is at least 12 years old you may just introduce the same or a different fault plus no one ever releases the pedal with the correct tool so a used one shifts around. Do it right, do it once.
  3. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    Jul 2018
    8 Post(s)
    Regards to the rear stop light bulbs. When I looks up 382 bulb it shows a single filament bulb? 380 shows as double filament?
    So which one is correct? Did you just get the 2 mixed up? Lol as I am confused now.
  4. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    133 Post(s)
    1988 Post(s)
    Yes 380 is the standard twin 5/25w and 382 single 25w.
  5. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    Jul 2018
    8 Post(s)
    Ahhh so I’ve got the wrong ones in then!!
    I’ve got single filament 382’s in my rear lights for the brake light.
    I should have the double filaments (380s) instead right?
    Sorry for the confusion.
  6. Re: Error Codes - 18041 - Accelerator Position Sensor 2 (G185)
    133 Post(s)
    1988 Post(s)
    Nope, two single filament 382 P21w also known as a BA15S (VAG N 107 732 2) and one BAX9s (VAG N 104 455 02)
  1. Wanted 1998 Audi S4 Accelerator position sensor **wanted**
    By Jon.burr in forum Parts & Accessory Price Requests
    Last Post: 21-05-2021, 03:20 PM
  2. 18047 - Accelerator Position Sensor 1/2 (G79/G185) and 01314 - Engine Control Module
    By ianlovatt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-12-2020, 11:35 PM
  3. anybody know wher the audi a3 tdi 2004 accelerator position sensor is
    By lance h in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-07-2012, 03:34 PM
  4. Please Help passat accelerator position sensor
    By flockton in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-09-2010, 04:02 PM
  5. accelerator pedal position sensor
    By 4udi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-03-2008, 01:45 PM
