Thread: Acceleration issue - turbo?
  1. Acceleration issue - turbo?
    Oct 2012
    United Kingdom
    I’m having an issue with acceleration, it becomes more of a problem when the rev is higher than 1000 when driving.
    If I leave the car idle or on neutral, no issue at all.
    Let’s say if I keep the acceleration pedal half pressed, the rev should smoothly going up but what I’m observing on mine is when it goes over 1000 it starts to loss a bit of rev occasionally. Does it sound like a turbo issue for example with too many residue? Would the turbo cleaner additive for fuel tank is likely to resolve the issue? Plugged to a computer with no fault code found.
  2. Re: Acceleration issue - turbo?
    1840 Post(s)
    Which fuel of the Devil engine is it, BXE, BKC, BLS or BMP and what are you reading the fault codes with?
  1. No turbo Acceleration
    By Mr_Vimto in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-02-2019, 06:52 PM
  2. Acceleration issue?
    By neebsta in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-01-2014, 12:39 AM
  3. Intermittent Loss of Acceleration issue
    By Fatimoo1 in forum Golf MK5 - 2004 - 2009
    Last Post: 04-01-2011, 06:31 PM
  4. 1st gear acceleration issue
    By bloostar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-06-2010, 06:11 PM
  5. Loss of acceleration / clutch issue.
    By MacHighlander in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-10-2009, 04:59 PM
