Thread: A/C pressure / Temperature sensor G395
  1. A/C pressure / Temperature sensor G395
    Apr 2018
    London uk
    HI All
    Can anyone please tell if I need to replace the motor and censor G395 or is this a voltage issue as I have replaced the battery last year?
    see below the output from the VCDS, sorry if this has been answered before
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
    Component: KLIMABETAETIGUNGH30 0020
    Revision: 00000052 Serial number: 00000030290807
    Coding: 0001046
    Shop #: WSC 02325 758 00200
    VCID: 1C37F02BDF21B569BD-8048
    2 Faults Found:
    00657 - Positioning Motor for Central Vents (V102)
    003 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 3
    Fault Frequency: 93
    Reset counter: 128
    Mileage: 218889 km
    Time Indication: 0
    Date: 2021.07.18
    Time: 15:03:27
    Freeze Frame:
    Voltage: 11.80 V
    Temperature: 35.0°C
    (no units): 96.0
    (no units): 64.0
    Temperature: 37.0°C
    00256 - A/C Pressure/Temperature Sensor (G395)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 102
    Mileage: 218889 km
    Time Indication: 0
    Date: 2021.07.18
    Time: 15:03:31
  2. Re: A/C pressure / Temperature sensor G395
    131 Post(s)
    1978 Post(s)
    Both common faults
  1. Replies: 9
    Last Post: 29-10-2020, 03:36 PM
  2. Lin Bus - 00256 - A/C Pressure/Temperature Sensor (G395)
    By gdallas in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 14-02-2019, 12:46 PM
  3. A/C Pressure/Temperature Sensor (G395)
    Last Post: 04-02-2019, 08:05 PM
  4. Removing front bumper for G395 sensor - question
    By 54A4Avant in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-07-2017, 02:18 PM
  5. Air con G395 sensor no vaultage help please
    By rapter in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-06-2017, 01:11 PM
