Thread: Engine issue
Results 1 to 10 of 20
  1. Engine issue
    May 2012
    essex
    *** is this, it started a couple of days ago and is getting worse, it's puffing out when the engine is running
    3.0tdi 2014
    Help
    Sent from my ELE-L09 using Tapatalk
    https://cloud.tapatalk.com/s/61e402dc...116_113259.mp4
    2007 3.0 tdi le mans : Hybrid turbo decat : miltek etc : 330-350 bhp : 450-500lbsft
    Visibility pack. Adaptive xenon, Privacy glass. Bose surround. Dvd nav. Comms pack, led plate lights.
    Miltek, custom map,hybrid turbo, decat improved airflow to intercoolers.
  2. Re: Engine issue
    134 Post(s)
    2021 Post(s)
    Injector seal leakage
  3. Re: Engine issue
    May 2012
    essex
    Will it be OK for a couple of days of school runs, only 5 minutes each way? Worried it may cause other damage
  4. Re: Engine issue
    134 Post(s)
    2021 Post(s)
    It should not get hot enough to ignite.
  5. Re: Engine issue
    May 2012
    essex
    Phew, lucky this didn't happen a fortnight ago. Spent 8 hours in the car coz off traffic
  6. Re: Engine issue
    134 Post(s)
    2021 Post(s)
    It is somewhat confusing why Audi decided to make the port that shows injector seals leaking discharge over the exhaust manifolds.
  7. Re: Engine issue
    May 2012
    essex
    I'd never heard of this issue but after research its incredibly come. Why on earth are there so many cases of vag injector seals failed?
  8. Re: Engine issue
    134 Post(s)
    2021 Post(s)
    It is rare for VAG to admit to a fault even inside the network but this one is covered under TPI 2042043/1 from June 2016
  9. Re: Engine issue
    Nov 2019
    Essex
    Is this still covered under some sort of warranty from audi then? I think our 2015 Q7 with CRCA engine is just starting to blow on a cylinder. I can just hear a ‘chuffing noise/hissing noise’ coming from the RH side of the engine.
  10. Re: Engine issue
    134 Post(s)
    2021 Post(s)
    IF you bought it from an Audi dealer and IF the service history is impeccable and was by an Audi dealer, 5 years old, mmmm doubt it but the worse they can say is no. The 2015 CRCA is covered under TPI 2042043/1. Print it out and shown them, if they deny it they are lying.
  1. 2.0 TDI engine issue BPW
    By mctb62 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-04-2020, 06:56 PM
  2. 5v engine issue
    By nobbybonez in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-10-2013, 04:47 PM
  3. First engine issue!
    By Ceber in forum Golf MK7 - 2013 - 2019
    Last Post: 08-05-2013, 07:51 PM
  4. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
  5. Please Help engine issue- 2 of them!
    By kennynj in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2008, 06:04 PM
