Thread: Column switch
  1. Column switch
    Hi, I just replaced my column switch due to a full beam fault, (see 2011 Polo full beam not working... ) but now I have a couple of warning lights for steering and stability control.
    I assume the steering angle sensor needs to be coded in, but is there anything I can do with a fault code reader?
  2. Re: Column switch
    134 Post(s)
    2021 Post(s)
    Usually a test drive with some lock to lock at standstill will clear the fault, if not code read time.
  3. Re: Column switch
    Thanks, I did try that. It clears when you switch off the motor with steering pointed straight ahead, but comes back as soon as I steer.
  4. Re: Column switch
    It doesn't throw up any fault codes, so I suspect it needs coding into the car...
  5. Re: Column switch
    134 Post(s)
    2021 Post(s)
    You didn't replace the slip ring did you? If there is a dash light on for the steering, a code will be stored, what are you using?
  1. column light switch
    By helmsy157 in forum 80 - 90
    Last Post: 01-02-2017, 12:33 PM
  2. Column Stalk/switch part number HELP!
    By TURBOPROP in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-01-2017, 05:29 PM
  3. Window switch, aircon, recirculation, demister switch and parking sensor not working
    By masterinengland in forum Touran - Sharan - Caravelle
    Last Post: 18-10-2015, 08:14 PM
  4. Question washer fluid leak on steering column - how to remove column shroud etc
    By flat4fanatic in forum Touran - Sharan - Caravelle
    Last Post: 29-03-2014, 11:28 PM
  5. Please Help Steering column switch trim torx screw size?
    By c4a5er in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-04-2009, 10:32 PM
