Thread: Passat B7 1.6tdi CAYC injector change
  1. Passat B7 1.6tdi CAYC injector change
    Jun 2021
    lincoln
    Afternoon.
    I'm investigating changing my 4th injector on my car. Every part of my research so far has indicated that when I disconnect the fuel lines with my trusty spanner it will dribble out. However a friend has told me its under alot of pressure and I'd need to bleed the system. Has anyone got any advice on this?
    Kind regards
    Dan
  2. Re: Passat B7 1.6tdi CAYC injector change
    135 Post(s)
    2027 Post(s)
    It can be under pressure, about 2000 Bar. Remember that you will have to enter the new injectors IMA value into the ECU.
  3. Re: Passat B7 1.6tdi CAYC injector change
    Jun 2021
    lincoln
    Thank you once again crasher for your help. I have a mech friend with the whole vcds shabang once its done.
    All the videos I've seen of them being changed on CAYC engines. With the battery disconnected. The fuel just dribbles out when they disconnect the lines.
  4. Re: Passat B7 1.6tdi CAYC injector change
    135 Post(s)
    2027 Post(s)
    Just be cautious, gloves, eye protection and a cloth over the fitting.
  5. Re: Passat B7 1.6tdi CAYC injector change
    Jun 2021
    lincoln
    Thanks again crasher. Excellent advice
  6. Re: Passat B7 1.6tdi CAYC injector change
    Jun 2021
    lincoln
    Hi @Crasher
    Do you know if the code you enter for the injectors is for the main body or the solenoid part? (i had to take off the solenoid bit when i used the slide hammer to get it out)
    i only ask as the recon one i have got from germany has a different code from the solenoid part that came attached to it. i have been specifically told to use the one hes provided and not the one on the solenoid cap. i realise you don't fit recon parts but this is just to get my run around car working.
    kind regards
    Dan
  7. Re: Passat B7 1.6tdi CAYC injector change
    135 Post(s)
    2027 Post(s)
    I do fit remanufactured parts, just not ones even the manufacturer won’t remanufacture; as I often say, Con or recon? When there is a big demand like this, the worms always come out of the woodwork to fleece the inexperienced and both will always be there, I was green and inexperienced once and fell for it. The IMA number on the old one should be the one in the ECU memory and the “new” one have the number printed on top.
  1. Question Passat B7 1.6tdi CAYC glow plugs
    By smith2001uk in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 23-09-2021, 04:22 PM
  2. A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    By Jon44w in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-11-2020, 10:24 AM
  3. Please Help CAYC Passat 1.6tdi 2012 p253600
    By Adots in forum 1.6TDi - Engine
    Last Post: 07-12-2019, 12:38 AM
  4. Question 1.6tdi CAYC Engine
    By djah in forum Golf MK6 - 2009 - 2013
    Last Post: 11-07-2019, 05:20 PM
  5. Please help vw passat 1,6tdi cayc
    By dorin in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 08-03-2018, 09:23 AM
