Hi all, after some brains to be picked if you would be so kind. I've got a 2011 VW Crafter which has a dodgy injector - leak off test filled bottle in 30 seconds and I'm getting P0087 and dropping into limp mode in certain scenarios.
I've picked up a used injector, but I understand the 7 digit code needs to be written to the ecu via VCDS.
Now, I do not have VCDS, will the van run ok without the adaptation being carried out?
