Thread: Is Clearing DTCs a Potential Problem?
  1. Is Clearing DTCs a Potential Problem?
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    Often when I do an AutoScan faults will be detected. To see if these are just temporary I do a clear all DTCs and re-scan to see if any have reappeared immediately and then a few days later. Other than preventing a service centre seeing these am I causing any other potential problems? Car is a late 2019 diesel Passat.
  2. Re: Is Clearing DTCs a Potential Problem?
    1841 Post(s)
    It is very rare for clearing faults to make things worse, a couple of times over the years I have done a code read on an engine which was slightly off or even just the MIL on and the situation has got much worse because the ECU had compensated for a faulty system and clearing the codes resets that compensation but it is extremely rare for it to happen.
  1. DSG Gearbox potential problem?
    By Allroad_2013 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-09-2021, 02:25 PM
  2. potential problem A4 2.5 TDI QAUTTRO
    By moodyblue in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2015, 05:41 AM
  3. Will clearing the fault codes solve this problem VW Sharan
    By sharan1.9 in forum Touran - Sharan - Caravelle
    Last Post: 18-01-2011, 01:49 AM
  4. DTCs not supported
    By babariba in forum VCDS - General Questions
    Last Post: 02-03-2008, 10:13 AM
  5. Interpret these DTCs plz
    By Loofer in forum VCDS - General Questions
    Last Post: 01-09-2007, 07:21 PM
