Thread: Help with Electrical fault
Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
  1. Re: Help with Electrical fault
    #41
    Mar 2017
    Newcastle
    Here again....fault is back.
    Looking at circuit diagram the 5V is connected to:
    ECU T60 pin 25 colour Yellow Blue
    1 - Engine Speed Sensor G28 pin 1 colour Yellow Blue
    2 - Position sender for charge pressure positioner G581 pin 3 colour Yellow Blue
    3 - EGR Potentiometer G212 pin T6y/1 colour Yellow Blue (part of EGR N18)
    4 - Fuel Pressure Sender G247 pin 3 colour yellow grey (not sure why wiring diagram shows different colour)
    5 - Throttle Valve Potentiometer G69 pin T5q/1 colour Yellow Blue (I'm guessing G69 is part of Throttle Valve Module J338 ?)
    So plan to change them all except EGR as they are connected to 5V from ECU T60 pin 25. Will ring them out too and check for short to 0V when all sensors unplugged and ecu unplugged.
    Question. I need to look but is it straight forward to change these. G28 already replaced.
  2. Re: Help with Electrical fault
    #42
    108 Post(s)
    1816 Post(s)
    Thats a bitch! Same fault code?
  3. Re: Help with Electrical fault
    #43
    Mar 2017
    Newcastle
    Yes
    Only Fault Found:
    4124 - Sensor Reference Voltage B
    P0651 00 [032] - Open Circuit
  4. Re: Help with Electrical fault
    #44
    108 Post(s)
    1816 Post(s)
    And a genuine VW ECU?
  5. Re: Help with Electrical fault
    #45
    Mar 2017
    Newcastle
    Yes....did not know there were others?
    No time to look at it at the moment. Using wifes car so it will have to wait as busy.
  6. Re: Help with Electrical fault
    #46
    Mar 2017
    Newcastle
    Are the circuit diagrams correct?
    Am I right thinking its one of the sensors or the wiring.
    Could it be interrupted supply to ecu? i.e. ignition switch.....though I'm thinking engine would cut out if power to ecu lost.
    So all I'm left with is fault is either a sensor I mention above or a short on 5V from ecu, or sensor lost earth (maybe wiring fault) or ecu lost signal (due to wiring fault) from sensor.
    Does that exhaust everything?
    Might be after christmas before I have time to check all these things.......
  1. HELP!! Electrical Fault
    By vw11 in forum Golf MK3 - 1993 - 1999
    Last Post: 18-12-2009, 10:25 AM
  2. Electrical fault
    By happydan in forum VCDS - General Questions
    Last Post: 07-09-2008, 06:15 AM
  3. Electrical fault
    By YodaTheCat in forum Golf MK3 - 1993 - 1999
    Last Post: 19-08-2008, 05:46 PM
  4. Electrical fault?!
    By SCORCHIO12 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2007, 11:45 AM
  5. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
