Thread: Help with Electrical fault
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
  1. Re: Help with Electrical fault
    Mar 2017
    Newcastle
    Update: Radio not used and left off since January. DTC's not cleared since January.
    Faults April 2022
    Sunday,03,April,2022,13:30:42:58947
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
    VCDS Version: 22.3.0.1 (x64)
    Data version: 20220225 DS336.1
    Ross-Tech: Home
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
    01-Engine -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 HW: 03L 907 309 R
    Component: R4 2,0L EDC H23 7453
    Revision: 42H23--- Serial number: 00000000000000 CVN: 3492FAA1
    Coding: 00190012042500080000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_ECM20TDI01103L906018 003010
    ROD: EV_ECM20TDI01103L906018_003_VW36.rod
    VCID: 67DA21709E8B97B763-8032
    VINID: 9E69EAAAA05BA929C22090050058D56F0A
    1 Fault Found:
    4124 - Sensor Reference Voltage B
    P0651 00 [032] - Open Circuit
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Readiness: 0 0 0 0 0
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90422KCP000S4
    Coding: 1082140000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_A05.rod
    VCID: 72EC4024A549621FC4-8026
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
    Component: E221__MFL-TK6 H06 0022
    Serial number: 40000000000000304063
    Coding: E20000
    3 Faults Found:
    147462 - Terminal 15
    B1148 12 [009] - Short to Plus
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 19
    Reset counter: 77
    Mileage: 98008 km
    Date: 2022.02.02
    Time: 16:03:31
    226057 - Ignition Starter Switch; Terminal S
    B1147 F1 [008] - Open or Short to GND
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 112
    Mileage: 99606 km
    Date: 2022.03.18
    Time: 12:26:02
    365080 - Controls in Steering Wheel
    U108E 00 [008] - No Communications
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 114
    Mileage: 99368 km
    Date: 2022.03.12
    Time: 10:39:17
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 5K0 920 971 AX HW: 5K0 920 971 AX
    Component: KOMBI H20 0420
    Coding: 470B01
    Shop #: WSC 00774 210 00000
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
    VCID: 05060BF884C765A7F1-8050
    No fault code found.
  2. Re: Help with Electrical fault
    Mar 2017
    Newcastle
    NO faults since April and car runs as normal. Faults start again in June with flashing coil on dash.
    Since January I do not clear DTC's....only scan to read them.
    June 2022.....Flashing coil on dash.....note - this can happen before I start the car.
    DTC's not cleared last time....so same faults shown....nothing new.
    Radio still turned off since January
    I turn ignition off pull out key, reinsert and start and no issues.
    Car ran as normal untill 13 days later then flashing coil and scan shows same fault.
    Monday,06,June,2022,11:51:31:58947
    VCDS Version: 22.3.1.4 (x64)
    Data version: 20220407 DS337.0
    Ross-Tech: Home
    01-Engine -- Status: Malfunction 0010
    VCID: 67DA21709E8B97B76E-8032
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 101070 km
    Date: 2000.00.00
    Time: 00:00:00
    Engine RPM: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 35 °C
    Intake air temperature: 17 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 11.980 V
    Unlearning counter according OBD: 38
    Exhaust gas temperature sensor 1: 20.0 °C
    Exhaust gas temperature sensor 2: -0.0 °C
    Exhaust gas temperature sensor 3: 71.8 °C
    Exhaust gas temperature sensor 4: 27.6 °C
    Shut-off timer: last engine shut-off time: 4662 s
    Coding: 1082140000
    VCID: 72EC4024A549621FC9-8026
    Coding: E20000
    3 Faults Found:
    B1148 12 [008] - Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 107
    Reset counter: 153
    Mileage: 98008 km
    Date: 2022.02.02
    Time: 16:03:31
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 15
    Reset counter: 149
    Mileage: 99606 km
    Date: 2022.03.18
    Time: 12:26:02
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 4
    Reset counter: 153
    Mileage: 99368 km
    Date: 2022.03.12
    Time: 10:39:17
  3. Re: Help with Electrical fault
    Mar 2017
    Newcastle
    Car taken to Audi Indy specialist...as car has never had emissions software upgrade and I do not wish to risk local VW upgrading software.
    29th June...something new....2 more Engine fault codes, speed sensor and Cyl 3 misfire.
    I cannot recall if I was driving or not but now I sometimes get engine fault symbol on dash as well as flashing coil....sometimes coil only sometime eng only and sometimes before I start car and car goes into limp mode.
    Had this a few times so booked car into a good VAG indy specialist who has official software.
    Indy explained 4 sensors on the 5V circuit with the fault. Tested each sensor and all working ok and wiring seems fine though known wiring issues with earlier build version and not my build version. Told Eng speed sensor can fail but rare and he did not think it so in this case, other 2 sensors (not told what) in his experience have never failed. The 4th is the EGR and he was surprised at 11 years old and 60k+ miles it had never been replaced. He could not be certain but suspected EGR. All DTCs reset and suggested I try it for a few weeks. Told to bring it back if it goes into limp mode and not to turn engine off.
    Next day come to start car and same faults as below are back.
    Sometimes pull key and restart and fault gone.....but drive a short distance and coil and or eng light come on and sometimes limp mode.
    On one occasion engine running, limp mode with same faults as below except no cyl 3 misfire reported, I reset DTC's and immediate rescan only showed Engine Speed Sensor fault...nothing else. So clearing DTC's did not clear all faults.
    Tried quite a few scans and resets of DTC's over last week or so as almost every day now car goes into limp mode either on start up or soon afterwards. What I have noticed is car revs at 950 when start with a fault....clear DTC's (engine running) and revs drop to 750.
    I can always start the car without too much trouble, not first fire as when car was ok, but immediately after that. On turn off engine does not immedaitely stop as when it was ok, but immediately after that.
    So if it was speed sensor would the car idle fine (even if at 950 rpm) and drive ok when no fault and still run smoothly but no power in limp mode?
    I see no EGR faults with Vagcom......but is the 950rpm idle when coil or eng light is on indicating its the EGR?
    Finally, more recently scanning and clearimg DTC's afterwards, the faults usually show random 1, 2 or 3 of 3 or sometimes no Steering Wheel faults......so I'm guessing this is not the fault.
    Always reports Engine Sensor Ref Voltage B and mostly Speed sensor, either speed sensor and misfire, or no speed sensor and just misfire (once so far) ...so I'm guessing cyl 3 misfire is not the issue.
    Where I'm at now is thinking of pulling battery and take off ECU connector and spray contact cleaner on pins and plug and reassemble.
    Any help or comments appreciated.
    Wednesday,29,June,2022,11:35:21:58947
    Ross-Tech: Home
    3 Faults Found:
    P0651 00 [175] - Open Circuit
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 10
    Mileage: 101485 km
    Date: 2000.00.00
    Time: 00:00:00
    Coolant temperature: 12 °C
    Intake air temperature: 13 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 10.820 V
    Unlearning counter according OBD: 40
    4087 - Engine Speed Sensor (G28)
    P0322 00 [096] - No Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 101596 km
    Date: 2022.06.24
    Time: 17:46:59
    Engine RPM: 861.00 /min
    Normed load value: 23.9 %
    Vehicle speed: 35 km/h
    Coolant temperature: 85 °C
    Intake air temperature: 24 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 13.900 V
    Engine start: start synchronization: EPM_MODE_BACKUP_CRS
    Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 60
    8737 - Cylinder 3
    P0303 00 [096] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 101580 km
    Date: 2022.06.24
    Time: 13:40:11
    Engine RPM: 934.50 /min
    Normed load value: 25.1 %
    Coolant temperature: 87 °C
    Intake air temperature: 38 °C
    Voltage terminal 30: 13.720 V
    Mean injection quantity: 5.65 mg/stroke
    Air mass: actual value (mg/stroke): 487.4 mg/stroke
    Fuel temperature: 47.0 °C
    Oxygen sensor 1 bank 1: lambda actual value: 6.802
    Pressure control valve adaptation factor: 1.0752
    Injection release status-Bits 0-7: 56
    Readiness: 0 1 0 0 0
    Coding: 1082140000
    Coding: E20000
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 136
    Reset counter: 167
    Mileage: 98008 km
    Date: 2022.02.02
    Time: 16:03:31
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 18
    Reset counter: 163
    Mileage: 99606 km
    Date: 2022.03.18
    Time: 12:26:02
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 4
    Reset counter: 153
    Mileage: 99368 km
    Date: 2022.03.12
    Time: 10:39:17
  4. Re: Help with Electrical fault
    1840 Post(s)
    If I was doing the job I would be recommending a new ECU
  5. Re: Help with Electrical fault
    Mar 2017
    Newcastle
    Thanks Crasher.
    As you pointed out last time regarding ECU. It sort of makes the most sense to me too.
    Is it worth (and can it be done...by who?....any recommendations) considering a repair?
    Is it worth considering second hand unit?...will it need programming? (I assume the unit needs to be identical model number etc)
    If new....does it need programing...or DIY remove battery, remove ECU, install new ECU then battery and go?
    If it needs programming...is this dealer only? (and I do not want emissions upgrade).
    Is it worth just part ex-ing (I'd declare the fault) for another golf....what could I expect dealer to knock off the car value?
    Bummer!....I love the car too...its been cherished....even indy commented on its condition.
    Thanks again for any advice.
    Kind Regards
  6. Re: Help with Electrical fault
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    It wasn't clear whether you had ruled out a physical problem with the 5V wire that might be giving intermittent problems.
    Re the ECU, if the flash is good then most decent professional / amateur tuners should be able to do a straight clone of the original. That should fix it if it was a bad (other) chip, connection, etc in the ECU.
    EDIT: Was thinking it was a Golf 5, but then re-read it is a 6. May be a bit harder but there are still places that do the equivalent ECU clone work.
  7. Re: Help with Electrical fault
    #17
    1840 Post(s)
    We have given up on ECU repair people, they are all useless. I have diagnosed a fair few of these being faulty but only a coupe had it done, most sell the car.
  8. Re: Help with Electrical fault
    #18
    Mar 2017
    Newcastle
    Thanks VAG-Abound.
    Indy could not find any issue with wiring...all looked good and no chafing. I'd looked at this already months ago and at one stage thought it might be so as after messing about with wires and adding spiralwrap I did get a period without issues. But that was last September.
    More recently (last few weeks), Indy has had it and I've looked again, even messing with wires while wife observed engine running and flashing coil. Nothing changed.
    Also Indy cited earlier version of my model, I take it as same golf MK6, just earlier build with different wiring loom, did have a history of wiring faults but not my model.
    Indy also pulled sensor plugs to examine for corrosion - all ok.
    So last few weeks almost daily, when I come to start it ....Engine fault reported (more recently) and engine light as well as flashing coil which I've had now and then for over 1 year....but now almost daily and now limp mode too.
    So short of splitting wiring loom and tracing each wire/sensor related to 5V wire (which I belive indy did...that is check wires at sensor point with a needle probe through insulation as well as viewing signals with software as he has access to wiring diagram), what do I do?
    If I had a wiring diagram I guess I could trace the cable....even fit a new one in parallel...but still uses existing plugs.
    So only job left I think I can do is pull battery, pull ECU plug, clean contacts with spray contact cleaner, same for plug, then reconnect, then battery and hope for the best!
    Thanks again for advice and comments.
  9. Re: Help with Electrical fault
    #19
    Mar 2017
    Newcastle
    Is it worth buying second hand? My ECU model number 03L 906 018 Software version 7453?
    This for example
    2008-2013 MK6 VOLKSWAGEN GOLF ENGINE ECU MODULE 2.0 DIESEL CFFB 03L906018 | eBay
  10. Re: Help with Electrical fault
    #20
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    All I can say is that people with the right skills could move your config to a 2nd hand unit. If I were you I'd ask for a "bundle" of them getting the right ECU, cloning it and fitting it. There's no point you buying a used ECU with no way to make it work, and they may want to choose what they use.
    I have no idea on their success or reputation, but this came up in a search as an example of some people being able to describe what needs to be done rather than start blind: VAG Coding - Component Protection - JK Car Electrics.
  1. HELP!! Electrical Fault
    By vw11 in forum Golf MK3 - 1993 - 1999
    Last Post: 18-12-2009, 10:25 AM
  2. Electrical fault
    By happydan in forum VCDS - General Questions
    Last Post: 07-09-2008, 06:15 AM
  3. Electrical fault
    By YodaTheCat in forum Golf MK3 - 1993 - 1999
    Last Post: 19-08-2008, 05:46 PM
  4. Electrical fault?!
    By SCORCHIO12 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2007, 11:45 AM
  5. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
