Thread: Cooling Issue - Thermostat?
  1. Cooling Issue - Thermostat?
    Dec 2021
    Nottingham
    I have a 2014 B7 2.0 Diesel Estate with CFFB engine and I notice that sometimes after short runs even in cold weather, the cooling fans are running when I stop even though the radiator is cold to touch. After a few minutes they switch off. This will happen two or three times and then not happen again for a few weeks
    The engine temperature guage doesn't go above 90 and I get no warning lights. I have a basic code reader and there are no errors showing.
    My simple old fashioned car knowledge suggests that the thermostat is getting stuck shut but I recognise things are more complicated these days.
    Can anyone suggest what might be wrong?
  2. Re: Cooling Issue - Thermostat?
    1840 Post(s)
    Ignore the dash gauge unless it is anything other than 90, they read 90 at a real 77 and still read 90 at a real 116 then suddenly shoot up, the idea is to stop people fretting over the minutia of the reading but it causes more problems than it solves. I would suspect the engines computer is trying to do a regeneration of the DPF but a fault code read could be a good idea plus reading off the DPF's soot and ash readings to see if a forced regeneration would be of benefit.
  3. Re: Cooling Issue - Thermostat?
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    The reason will be that you have turned off the engine while it is in the middle of a regen of the DPF.
    I've got the same engine in a Superb & it has happened on a couple of occasions.
    It's a problem when the car only does short journeys & can't complete the regen in one journey.
    Once it's completed a regen it will be fine for the next few hundred miles.
  1. Please Help Broke my map controlled cooling thermostat, how to replace?
    By The Norwegian in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-04-2016, 06:12 PM
  2. Bleeding Cooling System + Thermostat?
    By jagr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2011, 08:39 PM
  3. Please Help 1.6 SE Cooling issue
    By tbonetone in forum Golf MK4 - 1999 - 2004
    Last Post: 16-03-2010, 05:43 PM
  4. '97 Cab thermostat cooling fan issue
    By BobC in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 23-05-2009, 04:20 PM
  5. Question Engine cooling thermostat
    By lamont7615 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-04-2009, 08:34 AM
