Thread: Handbrake Guide Tube Replacement
  1. Handbrake Guide Tube Replacement
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    I’ve just changed my handbrake cables for new genuine parts (1K0 609 721 BE) but in the process of removing them I broke one of the guide sleeves / tubes that go through the body (1K0 711 952 A).
    How are these replaced?
    I also struggled to get the new cables into the guide tubes (even with some grease).
    If anyone has done this before please let me know.
    Thank you.
  2. Re: Handbrake Guide Tube Replacement
    Jul 2018
    8 Post(s)
    Just found a good write up after a google search....
    Handbrake cable replacement in a Golf MK5
  3. Re: Handbrake Guide Tube Replacement
    Apr 2009
    Durham
    Thank you willdude.
    Hope it helped you, the rubbers themselves tend to dry out.
    The little black plastic is a removable grommet, it may have been this preventing you inserting it.
    If you want to ask me something directly (my.name@gmail.com) or feel free to pm me on here if you're still stuck and don't get a response from anyone.
  4. Re: Handbrake Guide Tube Replacement
    Nov 2016
    Ireland
    14 Post(s)
    I recently replaced the handbrake cable and sleeve on a golf. I found it straight forward, you're best doing it from inside the car with the seat up etc, and access to the guide tube etc.. start by fitting the guide tube from inside the car to the outside, you'll see the old Vw black sticky pad which will visually help to put it in the correct position.
    It will be awkward if you're trying to put the tube and cable in from the outside first.
  5. Re: Handbrake Guide Tube Replacement
    Apr 2009
    Durham
    Quote Originally Posted by TdiBlacky140 View Post
    Much easier, when I was under the car it was a hassle, because you can't see the routing. Once I ripped up the rear bench / carpet, it was done in minutes and a lot easier to troubleshoot
  6. Re: Handbrake Guide Tube Replacement
    Jul 2018
    8 Post(s)
    Sent you an email Andy. Thanks for your help.
  7. Re: Handbrake Guide Tube Replacement
    Apr 2009
    Durham
    Quote Originally Posted by willdudeuk View Post
    Thanks I haven't received an email from you however?
    My names andrew btw not andy, so if you've sent it to that it won't work
  1. Replies: 142
    Last Post: 10-04-2019, 08:42 PM
  2. Tube diameter for replacement audi 80 cabriolet (1996) windscreen washers
    By loz65 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 02-11-2017, 12:34 PM
  3. Question ABS/ESP Modulator replacement guide
    By gunnag in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-10-2013, 01:44 PM
  4. Total Eclipse of the Heart - YOU TUBE - YOU TUBE...
    Last Post: 26-06-2008, 11:59 AM
  5. Lamp Replacement Guide
    By shahabudeen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-04-2007, 10:12 AM
