Thread: Dreaded error 01314
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Dreaded error 01314
    Dec 2021
    England
    If you could email me the diagram that would be great
    Email address is
  2. Re: Dreaded error 01314
    108 Post(s)
    1816 Post(s)
    Done
  3. Re: Dreaded error 01314
    Mar 2010
    Derry ireland
    59 Post(s)
    on this problem he has to first & foremost sort out diagnostic connector not communicating ecu untll he gets this sorted out he cannot go any further
  4. Re: Dreaded error 01314
    Dec 2021
    England
    So the wire to pin 18 had basically no power going to it according to the wiring diagram this is a permanent live.
    Thought what have I got to loose cut it and connected it directly to the battery and boom engine runs again, loads of fault codes with everything not communicating with everything (I assume due to the battery being off) cleared all codes went for a drive and nothing has came back. I assume the wire to pin 18 has a break in it somewhere
  5. Re: Dreaded error 01314
    108 Post(s)
    1816 Post(s)
    I will have a look at the diagram tomorrow but I have just got back in and having trouble seeing straight, single, focusing
  1. Return of the 01314 code with crank but no start
    By Lincs-sline in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 07-03-2021, 06:47 PM
  2. Fault codes 01314 AND 00526
    By 1611AZTEC in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2021, 07:09 PM
  3. Bora 1.9TDI Mk4 2002 - Error 18074 and 01314
    By phildamb in forum Bora - 1998 - 2005
    Last Post: 08-10-2013, 05:42 PM
  4. ESP light on 01314 and 17656 codes
    By A3DS3 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 04-06-2012, 09:14 AM
  5. Non Starter - VAG Code 01314
    By hapz1 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2010, 10:53 PM
