Thread: Dreaded error 01314
Results 1 to 10 of 15
  1. Dreaded error 01314
    Dec 2021
    England
    Hello,
    I have bought a cheap golf as a run around was working fine until the other day I went out and it wouldn't start. Checked voltage on battery and was showing just over 12v and engine was spinning freely, plugged in the Carista and it was not able to connect to the ECM or the OBD2, a lot of the modules have code 01314 logged with no communication to the ECM. I have checked the fuses and all seem to be good (checked with an old LED bulb and using the fuses as an inline fuse).
    I have removed the ECU and all pins look to be free from damage and oxidization.
    Checked the voltage on t94a plug on 3, 5, 6 which is a switched live but only works if I jump the relay. Earth present on pin 1, 2, 4
    The relay 100 in the engine bay seems to not be clicking on but jumping this relay then send the power to the ECU but the engine still doesn't fire.
    Car is a 2008 VW golf mk5 with the BMN pd170 engine
  2. Re: Dreaded error 01314
    1841 Post(s)
    To me it is more the dreaded BMN, a foul smelling eye watering environmental disaster; can you communicate with all the other controllers such as ABS and dash? I know it sounds daft but get the ECU nice and warm then try it.
  3. Re: Dreaded error 01314
    Dec 2021
    England
    Yeah can communicate with everything else, had the ecu out and put it in the house, still nothing stole my mates bmn ecu still not recognised in my golf but my ecu would be recognised in his, didn't start them tho due to immobiliser
  4. Re: Dreaded error 01314
    Mar 2010
    Derry ireland
    60 Post(s)
    The main control relay 0n this model fires up ecu pin nos 3-5-6. fuel pump relay. glow plug control module. oxygen sensor. clutch position sensor. turbo pressure relay. exhaust gas cooler solenoid.inlet manifold tuning. If you ecu is not responding check you have 12vs permanent at term 16 & check earth at pin nos 4 pulsed earth & pin 5 chassis ground. When you bridged relay terminals marked 30 & 87 you were by passing pin 87 coil supply voltage. you should of earthed terminal 86 to see if all these units is being fired up
  5. Re: Dreaded error 01314
    Dec 2021
    England
    When I checked the voltage I 3-5-6 was getting power but only if I jumped the relay, I put a known working relay in and still no power to pins.
    When you say term 16 do you mean pin 16 on the t94 plug?
    I have earth's at 1-2-3 on the
    I will also earth pin 86 and give that a go
    Also I don't get a fuel pump prime sound or a glow plug light so I assume I'm not getting power to them either
  6. Re: Dreaded error 01314
    Dec 2021
    England
    Earthed pin 86 Still nothing
  7. Re: Dreaded error 01314
    1841 Post(s)
    Check the three power feeds to pins 3, 5 and 6 of the 94 pin plug have an ignition live power feed from fuse 13 in the engine bay fuse box and pin 18 has an ignition live feed from fuse 2 in the dash side fuse board
  8. Re: Dreaded error 01314
    Dec 2021
    England
    With the relay plugged in I have no power going to pin 3 5 6 and nothing at fuse 13
    With a jumper cable plugged in I get power at pin 3 5 6 and fuse 13
    Pin 18 I'm getting 3v with jumper and nothing with relay
  9. Re: Dreaded error 01314
    Dec 2021
    England
    I have noticed I have no power at fuse 13 until I earth the relay when I do that I get power to fuse 13 but still not starting
  10. Re: Dreaded error 01314
    1841 Post(s)
    Without power at SB13 (the engine bay main fuse box is called SB) the ECU has no power so if you jump the relay sockets respective to 30 and 87 you restore power BUT you are not addressing why the relay is not operating. It is earth triggered by the ECU and has dedicated constant live unfused power from fuse SB 10 and this line also supplies the relay contact 30 with power. If fuse SB10 is blown/missing it has no affect on anything else. With the relay positions 30 and 87 jumped and power restored to the ECU proves the feed to 30 and SB10 are present so fuses SB 10, 13, 14, 15, 21, 22, 23 and 24 should have battery power with the relay terminals jumped. I will email you the wiring diagram as I am going to be off until the 4th so I will be able to help further, but it is in German.
  1. Return of the 01314 code with crank but no start
    By Lincs-sline in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 07-03-2021, 06:47 PM
  2. Fault codes 01314 AND 00526
    By 1611AZTEC in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2021, 07:09 PM
  3. Bora 1.9TDI Mk4 2002 - Error 18074 and 01314
    By phildamb in forum Bora - 1998 - 2005
    Last Post: 08-10-2013, 05:42 PM
  4. ESP light on 01314 and 17656 codes
    By A3DS3 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 04-06-2012, 09:14 AM
  5. Non Starter - VAG Code 01314
    By hapz1 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2010, 10:53 PM
