Thread: 1.6 TDI squealing noise after turbo replacement?
  1. 1.6 TDI squealing noise after turbo replacement?
    Apr 2016
    peterborough
    Anyone know what this noise is? It happened after replacing the turbo as I had no boost. I will admit I put a used turbo sold by a private seller but checked for play in the turbines both sides before purchasing...
    I have retightened the manifold bolts thinking they might be loose but it hasn't fixed the issue. I have removed the dpf as I thought maybe it was related but it wasn't. The smoke you can see is from the turbo to dpf side, goes away ones the dpf is connected back up. But the screeching noise what can it be? Could it be a faulty turbo even though I didn't feel any play on the turbines????? Also if I disconnect the boost solenoid valve connector from the top of the engine, the noise goes away but will come back as soon as I reconnect it.
    https://www.dropbox.com/s/7sa7llzjyf8wn97/VID_20211228_155517.mp4?dl=0
    Hope
    I don't have to redo the job!!!!
  2. Re: 1.6 TDI squealing noise after turbo replacement?
    Apr 2016
    peterborough
    Nobody knows?
    I am thinking its either the manifold gasket as I used the old one and didnt replace it or its the turbo itself but the problem is if I open it all up again do I just replace the gasket and put it all back together again or replace the turbo itself.. Such a mess
  3. Re: 1.6 TDI squealing noise after turbo replacement?
    1840 Post(s)
    Sounds like the EGR pipe gasket at one end or the other.
  4. Re: 1.6 TDI squealing noise after turbo replacement?
    Apr 2016
    peterborough
    Hello crasher thank you for reply, So definitely can't be a bad turbo? Just trying to weigh up if it's worth opening everything to replace gaskets or open it all and replace the turbo too...
  5. Re: 1.6 TDI squealing noise after turbo replacement?
    1840 Post(s)
    Could be a bad turbo, it is why we now refuse to use second hand parts, the hours they have lost me over the last 40 years could make me weep, you should never reuse gaskets, it is false economy; do it right so you only do it once. The most common leak is on the pipe back up to the head which is tricky and prone to cross threading.
  6. Re: 1.6 TDI squealing noise after turbo replacement?
    Apr 2016
    peterborough
    I know but I thought I was being clever by spending just £70 on a used turbo rather than £250 for reconditioned.. lesson learnt. I still have a big doubt as to believe it's the turbo because the car is pulling good and strong..
    By the pipe going "back up to the head" which pipe exactly do you mean? Are you talking about the oil feed/return pipe going from under the turbo to the banjo bolt on the engine block?
    I can see some oil drip coming from this oil feed pipe but not certain if that is the cause for my squealing noise.
    Thanks.
  1. Question Deep vibrating noise when idling, squealing noise when turning wheel full lock - HELP! 1.9 TDI
    By vonny232 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-08-2016, 01:22 PM
  2. Squealing noise from Clutch when setting off in 1st
    By evilbane in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-01-2014, 12:57 AM
  3. Squealing/vibrating noise
    By ince03 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-02-2011, 08:35 PM
  4. Please Help squealing noise when cold
    By bodger5 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-06-2009, 01:57 PM
  5. Squealing noise under bonnet
    By animal in forum Polo - Derby - Lupo - Fox
    Last Post: 02-06-2008, 10:38 AM
