Thread: MK6 TDI Limp mode DPF
  1. MK6 TDI Limp mode DPF
    Dec 2021
    Northern Ireland
    Hi guys,
    My 2.0 tdi recently went into limp mode (or what i assume is limp mode) after driving on when the exhaust gas temperature sensor was faulty. The car couldn't a do a regen because of that and then clogged the DPF. I took the DPF out cut it open, deleted it and welded it back up thinking this would be a cheap solution to fix the problem. Unfortunately the car is still in limp mode (or whatever it is). Would I need to get the DPF mapped out to get the car out of limp mode or could it be another problem elsewhere. Thanks
    error codes (on cheap code reader)
    P246E - EGT Sensor
    P2463 - Particulate Filter Restricted- soot bank 1
    P0544 - EGT Sensor
  2. Re: MK6 TDI Limp mode DPF
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    You have deleted the DPF but the ECU software still thinks the DPF is there.
    The ECU is still seeing the faulty EGT sensors so will remain in limp mode.
    You will have to get the DPF deleted from the ECU software, or replace the DPF with a good one & replace the 2 faulty EGT sensors.
  3. Re: MK6 TDI Limp mode DPF
    108 Post(s)
    1816 Post(s)
    How are you going to get it through the NCT?
  4. Re: MK6 TDI Limp mode DPF
    Mar 2010
    Derry ireland
    59 Post(s)
    I think you were correct when you quoted. Or could it be another problem elsewhere. you cannot take on board what any cheap code reader comes up with can you post up your engine code at lest you know now its not a dpf problem.
  1. Limp mode
    By andreweastsusse in forum Touran - Sharan - Caravelle
    Last Post: 28-05-2018, 02:06 PM
  2. Is this limp mode?
    By NickJ in forum Touran - Sharan - Caravelle
    Last Post: 20-09-2015, 01:09 PM
  3. Replies: 5
    Last Post: 07-02-2013, 06:52 PM
  4. "Limp Mode" - Audi A4 2002 2.0 Sport in Shoutdown Mode
    By ARJ230580 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-09-2012, 11:14 PM
  5. Question Limp mode/safe mode
    By fourringsrus in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-01-2010, 02:06 PM
