Thread: 3.0 v6 sport running rough again
Results 1 to 10 of 10
  1. 3.0 v6 sport running rough again
    Liverpool
    11 Post(s)
    My Audi is running a little rough, but only when accelerating between 1500-2500rpm. Was serviced less than 1k miles ago, new oil and filter, air filter, plugs, rocker cover gaskets. Been missing on low revs for the last 3 or 4 weeks. Have scanned it and no codes present.
    was running lumpy a few months ago, and I ended up replacing all 6 coil packs. That was running rough constantly but this is just when accelerating on low(ish) revs
    ive run some injector cleaner through just in case. Car has done 130k miles
    any ideas please guys?
  2. Re: 3.0 v6 sport running rough again
    1837 Post(s)
    I have known none genuine coil packs fail very quickly, what did you fit?
  3. Re: 3.0 v6 sport running rough again
    Liverpool
    11 Post(s)
    Hi Crasher
    they were just cheap Starline ones from ECP. Funny you say that I had to get one replaced as one of the new ones failed after about 3 weeks. Picked it up on a scan.
    this kind of misfire is only at low revs when accelerating, not when idling or driving normally. Plus wouldn’t another duff coil pack show up on a scan? No engine faults came up when I scanned it recently?
  4. Re: 3.0 v6 sport running rough again
    1837 Post(s)
    I won’t touch that crap, Bosch or genuine.
  5. Re: 3.0 v6 sport running rough again
    Liverpool
    11 Post(s)
    Starting to wish I’d done the same Crasher. But wouldn’t another failed coil pack show up in a scan? I was getting ‘misfire cylinder 2’ until I replaced the duff one. It’s running better, not missing all the time, just at low revs when you accelerate, there’s hesitation and a slight delay. Not quite a ‘cough’, but it’s there
    any other ideas?
  6. Re: 3.0 v6 sport running rough again
    1837 Post(s)
    I forgot to ask what the pugs are and how old? With suspect brand coil packs, in this situation I tell a customer that I must know the plugs and coil packs are perfect and go from there BUT unfortunately no guarantee of success as otherwise I could spend countless hours at £72 an hour chasing the fault only to come to the initial conclusion.
  7. Re: 3.0 v6 sport running rough again
    Liverpool
    11 Post(s)
    Sorry Crasher I should of said, they are NGK (BKR6EKUB) from EuroCarParts
  8. Re: 3.0 v6 sport running rough again
    Mar 2010
    Derry ireland
    60 Post(s)
    This problem covers a multitude is there any time this happens either hot or cold can you post post up engine code. It would not go amiss to check out engine coolant temp sensor & fuel temp sensor if your drives ok after 2500 rpm then i cannot see this a coil problem
  9. Re: 3.0 v6 sport running rough again
    Liverpool
    11 Post(s)
    Thanks mickeybo. Had an engine light come on yesterday and got these 2 codes:
    p0421 warm up catalyst efficiency below threshold bank 1
    p0431 warm up catalyst efficiency below threshold bank 2
    am guessing either the cats themselves, or the oxygen sensors after the cats? Any easy way to pinpoint the issue?
    and I don’t live anywhere near an Audi main dealer, so where would you order oxygen sensors from if needed?
  10. Re: 3.0 v6 sport running rough again
    1837 Post(s)
    I have had a number of these where the primary cat has disintegrated usually due to driving with a misfire for too long.
  1. rough running
    By paulthefox in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-07-2014, 09:25 PM
  2. Please Help T4 running rough
    By v8power in forum The Commercial Range
    Last Post: 07-05-2013, 12:00 AM
  3. Please Help Passat 170 Sport Coolant / Rough Running Issues
    By craig245t in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-01-2013, 04:50 PM
  4. Please Help A4 Cab 3.0 Very Rough Running
    By Joe9T in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-09-2011, 03:33 PM
  5. Mk3 GTI 8v - Rough running
    By scorchi0 in forum Golf MK3 - 1993 - 1999
    Last Post: 31-12-2007, 02:25 PM
