Thread: Seat Ibiza 6J '58 1.4 Help
  1. Seat Ibiza 6J '58 1.4 Help
    Dec 2021
    Horley, UK
    Hi, background info: my sister-in-law recently tried to jump start her car and shorted the jump leads whilst ignition on. The car now has a power steering fault light on, car starts and runs but no power steering at all.
    I ran an auto scan as below, but no comms with ECM, power steering etc. Wondering if anyone can help with where to start on this?
    Code:
    Friday,24,December,2021,12:43:43:11988
    VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
    Data version: 20210903 DS330.0
    Ross-Tech: Home
    VIN: VSSZZZ6JZ9R026309   License Plate:
    Chassis Type: 6J-SE25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 44 4B 56 77
    VIN: VSSZZZ6JZ9R026309   Mileage: 151200km-93951miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    44-Steering Assist -- Status: Cannot be reached 1100
    4B-Multifunc. Module -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine
    Cannot be reached
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6R0 907 379     HW: 6R0 907 379
       Component: ABS8.2 front  H03 ABS8.2 front  H03 00040004
       Revision: --------
       Coding: 100224DB016F00B8082824E280DA00000000
       Shop #: WSC 04941 000 00000
       VCID: 7BA3FF2A23A78D93F23-802E
    No Faults Found
      or DTCs not supported by controller
      or a communication error occurred
    Address 08: Auto HVAC        Labels: 6J0-820-045.clb
       Part No SW: 6J0 820 045     HW: 6J0 820 045
       Component: J301  Klimaanlage   0280
       Revision: 00 23 08    Serial number: 0000000019438-
       Shop #: WSC 00000 000 00000
       VCID: 6393A74AB7575553DA3-8036
    No fault code found.
    Address 09: Cent. Elect. (J519)       Labels:. 6R0-937-08x-09.clb
       Part No SW: 6R0 937 087     HW: 6R0 937 087
       Component: PQ25 BCM      H06 0011
       Revision: BF006001    Serial number: 9425A162080621
       Coding: 7C882BA88861010000300000660B1CC80040400F608C00002000
       Shop #: WSC 64564 324 38760
       VCID: 7AADFA2E2CDDB49BE95-802E
       Subsystem 1 - Part No SW: 6R0 959 802     HW: 6R0 959 802   Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  001 0221
       Serial number: --------------------
       Coding: 030000
       Subsystem 2 - Part No SW: 6R0 959 801 B    HW: 6R0 959 801 B  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  001 0225
       Coding: 020000
       Subsystem 3 - Part No SW: 6R0 959 811     HW: 6R0 959 811
       Component: J388__TSG_HL  001 0227
       Coding: 000000
       Subsystem 4 - Part No SW: 6R0 959 812     HW: 6R0 959 812
       Component: J389__TSG_HR  001 0228
       Coding: 000000
    6 Faults Found:
    03301 - Response Closing Status of Drivers Door
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 2
                        Fault Frequency: 73
                        Reset counter: 96
                        Time Indication: 0
    03302 - Response Closing Status of Passenger's Door
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 7
                        Reset counter: 96
                        Time Indication: 0
    03303 - Response Closing Status of Rear Left Door
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 96
                        Mileage: 151207 km
                        Time Indication: 0
                        Date: 2016.05.16
                        Time: 00:00:10
    03304 - Response Closing Status of Rear Right Door
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 254
                        Reset counter: 96
                        Mileage: 110495 km
                        Time Indication: 0
                        Date: 2013.07.03
                        Time: 04:02:10
    00446 - Function Limitation due to Under-Voltage
                002 - Lower Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 96
                        Mileage: 0 km
                        Time Indication: 0
                        Date: 2016.05.16
                        Time: 00:00:01
    01044 - Control Module Incorrectly Coded
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 95603 km
                        Time Indication: 0
                        Date: 2011.10.17
                        Time: 00:00:01
    Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
       Part No SW: 6R0 959 655     HW: 6R0 959 655
       Component: VW10AirbagA05 H07 0013
       Revision: --------    Serial number: 003000000000
       Coding: 003035
       Shop #: WSC 06401 785 00200
       ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 7F5B0B3A377F91B3DEB-802A
       Crash sensor for side airbag: driver side:
       Serial number: 3492ERB402J53FB8NBML
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 3502ERB402T5EOKUVSQH
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Part No SW: 6J0 920 900 K    HW: 6J0 920 900 K
       Component: KOMBI         016 0016
       Serial number: 00000000000000
       Coding: 410A00
       Shop #: WSC 06402 785 00200
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
       ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
       VCID: 2F3B1B7AA79FA1330EB-807A
    1 Fault Found:
    13638912 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuerger�t f�r Lenkhilfe: keine Kommunikation]
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 0
                        Mileage: 151207 km
                        Date: 2021.12.24
                        Time: 00:00:49
    Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 0011
       Coding: 022300
       VCID: 70B9D8067AA1FECB571-8024
    1 Fault Found:
    01309 - Power Steering Control Module (J500)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 56
                        Mileage: 151207 km
                        Time Indication: 0
                        Date: 2016.05.16
                        Time: 00:00:52
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          016 0016
       Serial number:
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
       ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
    1 Fault Found:
    9456128 - Engine Control Module (ECM) not authorized
              B104A 00 [008] - -
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 4
    Address 44: Steering Assist
    Cannot be reached
    Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
       Part No: 6J0 959 441 A
       Component: MF-Modul       0007 0001
       Coding: 0000002
       Shop #: WSC 77005 000 00000
       VCID: 313F1D02BD2BB7C318F-8064
    Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
       Part No SW: 6J0 035 153 B    HW: 6J0 035 153 B
       Component: Radio G3 UL   H55 0033
       Revision: 0H001001    Serial number: SEZ1Z2H5670684
       Coding: 0503040002
       VCID: 2313E74AFBD715539A3-8076
    Address 77: Telephone        Labels: 5P0-862-335.lbl
       Part No SW: 5P0 862 335 D    HW: 5P0 862 335 D
       Component: FSE_2P7x        H31 0120
       Revision: 00000001    Serial number: 00000005004035
       Coding: 0000720
       VCID: 34311416423982EB739-8060
    End----------(Elapsed Time: 02:05, VBatt start/end: 14.2V/14.3V)-----------
  2. Re: Seat Ibiza 6J '58 1.4 Help
    134 Post(s)
    2012 Post(s)
    I am a VAG specialist and jump leads are banned from the building, if I caught a tech using them they may get attached to parts of his anatomy which could cause discomfort . I suspect there is some serious damage to a number of the vehicles ECU’s but the first step (you have done the first, nearly) is to check the fuses on the battery then attempt to discover why there are no steering ECU comms, this unit is directly under the battery below the inner wing.
  3. Re: Seat Ibiza 6J '58 1.4 Help
    Dec 2021
    Horley, UK
    So finally checked each and every fuse - all are ok, but still no comms as above, I have a feeling that this means some very costly damage to multiple control modules?
  4. Re: Seat Ibiza 6J '58 1.4 Help
    Mar 2010
    Derry ireland
    67 Post(s)
    The power steering control unit on this vehicle engine code bxw is located n/hand side engine bay marked d-c-b terminal b4 ign on 12vs Terminal c1 12vs Terminal c2 ground
  5. Re: Seat Ibiza 6J '58 1.4 Help
    134 Post(s)
    2012 Post(s)
    As I said on the other forum, I would be installing a new pump
  1. seat ibiza air con
    By mystic 8v in forum Ibiza - Cordoba
    Last Post: 20-07-2011, 11:48 PM
  2. Seat Ibiza 1.9 tdi DAB
    By McNeill in forum Ibiza - Cordoba
    Last Post: 26-08-2008, 01:06 PM
  3. Seat Ibiza TDI MK3
    By punkfreak in forum Ibiza - Cordoba
    Last Post: 05-08-2008, 02:23 PM
  4. my seat ibiza mk3
    By adam1.4biza in forum Show 'n' Shine - Post your efforts here
    Last Post: 03-06-2008, 12:55 PM
  5. Seat Ibiza
    By P Groves in forum New Member Introductions
    Last Post: 28-05-2008, 03:01 AM
