Thread: Oil pressure light 'STOP'?
  1. Oil pressure light 'STOP'?
    Mar 2017
    Hampshire UK
    Looking for pointers, 1.9 pd, 161k.
    Car's running absolutely fine, no previous symptoms. Cold start today starts and runs normally. after about 15-20 secs. alarm chime, red oil light and 'STOP'. Obviously switched off. Scratched head, check oil level. Low-ish but well within the safe zone, topped up a little to be sure. Left it a few minutes, try again, same again.
    Not getting the level warning, just the red light after about 20 secs. running. I would have expected the light to be on from key turn if there was a genuine absence of pressure.
    Thoughts anyone?
    Thanks.
    1 person in 10 understands binary, the other one doesn't.
  2. Re: Oil pressure light 'STOP'?
    Mar 2017
    Hampshire UK
    Well, it appears (hopefully) it was a bad connection on the sensor by the filter.
    Rob.
  3. Re: Oil pressure light 'STOP'?
    1837 Post(s)
    Could be damp in the sensor plug
  4. Re: Oil pressure light 'STOP'?
    Mar 2017
    Hampshire UK
    Well, this is embarrassing!
    I've only had the car 16 years, you'd think I'd know the difference between the red oil light and the red coolant light. Apparently not and now feeling a bit of a dufus! Start up, a red light, chimes, switch off quick, assume the worst. What a drama queen. Thankfully didn't get a garage involved.
    Anyhow, red coolant light, 'stop check coolant' message on a cold engine with correct level in the tank? Took the plug on and off the tank a few times in case of a bad connection and hasn't done it since (so far). Runs fine and comes up to temp as normal.
    Anything else that could bring up the red coolant light like that?
  5. Re: Oil pressure light 'STOP'?
    1837 Post(s)
    Quote Originally Posted by Hair Bear View Post
    Tut tut have you been at the communion wine again
  1. Oil pressure warning light - STOP! : 1.9 tdi PD
    By DMcCo in forum Golf MK5 - 2004 - 2009
    Last Post: 25-07-2019, 09:07 AM
  2. Please Help STOP. Low oil pressure
    By TaximanWsM in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-09-2013, 12:39 PM
  3. Please Help Stop engine/oil pressure warning light comes on
    By GnasheRRR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-10-2011, 11:05 AM
  4. Stop!!! Low Oil Pressure!!!!!
    By bubblesaint in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-03-2011, 04:43 PM
  5. Please Help STOP: Oil pressure
    By blackpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2009, 08:53 PM
