Thread: Drivers door not opening from outside
  1. Drivers door not opening from outside
    Jun 2009
    Has anybody else experienced this? The door opens fine from the inside, but is virtually impossible to open from outside. I had the door card off today and everything seemed to be moving as it should which is odd. Any tips would be appreciated - it's becoming slightly annoying having to climb over the passenger seat every time I want to go anywhere!
  2. Re: Drivers door not opening from outside
    1840 Post(s)
    I would expect it to be the lock module
  3. Re: Drivers door not opening from outside
    Jun 2009
    Stupid question Crasher before I order a replacement - are the module and the actuator the same thing?
  4. Re: Drivers door not opening from outside
    1840 Post(s)
    I missed this being a 4B, there are variations. Message me the reg or post the VIN.
  5. Re: Drivers door not opening from outside
    Jun 2009
    PM sent. Thank you.
  6. Re: Drivers door not opening from outside
    1840 Post(s)
    I have in the dim and distant past have problems with wear in the handle unit with it not operating the door lock unit sufficiently and to test this you take both out and check them on the bench where the problem should be apparent. If it is in the handle the repair kit (Audi number 4B0 898 105) used to deal with this is obsolete as is the handle but the lock unit 402 837 016 is still available at £197.16 but I do seem to remember it was the handle being the problem. The handle and the repair kit are both stocked by Audi Tradition in Germany but not only are they offline until next year, the won't send to the UK because they can't cope with Brexit, even tough they sell to other non EU countries all over the planet! The repair kit is available on fleaBay but I seem to remember this not being successful.
  1. Please Help Drivers door not opening due to DEADLOCK.
    By indyandy in forum Golf MK4 - 1999 - 2004
    Last Post: 14-04-2015, 04:39 PM
  2. Please Help Drivers door not opening.
    By SmokeyUK in forum Golf MK4 - 1999 - 2004
    Last Post: 08-04-2015, 07:09 AM
  3. Question Drivers door handle / opening door
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2010, 08:19 PM
  4. A6 Drivers Door Lock Sticking and door occasionally not opening
    By CliffA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-02-2010, 10:53 PM
  5. Noisey drivers door opening
    By curryholic in forum Touran - Sharan - Caravelle
    Last Post: 24-04-2007, 06:06 PM
