Thread: 2.8l tdi (inline 4) (Lt 46) 96 kw, 2001 - performance issues / questions
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: 2.8l tdi (inline 4) (Lt 46) 96 kw, 2001 - performance issues / questions
    Mar 2010
    Derry ireland
    60 Post(s)
    On all these early vw s they all had a needle lift sensor including your vehicle needs to be checked out was always a common fault. can you post up your engine code or reg n0
  2. Re: 2.8l tdi (inline 4) (Lt 46) 96 kw, 2001 - performance issues / questions
    Dec 2021
    Stockholm SWEDEN
    Thanks for the info on boost levels. (And you got a point about the diesel shop, but i have bad experience with shops in general, and also i would have to rip everything out of the truck.)
    I did post engine code (ATA) and vin number (Vw1zzz2dzyh026313). And also the topic of the thread is all about the engine.
    And the 2.8 liter does not have needle lift sensor?
  3. Re: 2.8l tdi (inline 4) (Lt 46) 96 kw, 2001 - performance issues / questions
    1840 Post(s)
    I have very basic experience on this engine but it is not unlike the earlier non indirect systems which have no feedback
  4. Re: 2.8l tdi (inline 4) (Lt 46) 96 kw, 2001 - performance issues / questions
    Dec 2021
    Stockholm SWEDEN
    Ok, new update.
    After installing an egt gauge, today i had to go pick up a trailer.
    On the way there, egt was 550-600 _C_, just cursing at 80 km/h.
    On the way back, still with no load just truck and trailer empty (dragging some wind how ever), egt stayed at about 600 - 800 C, in slight grades it passed 900 a few times.
    Sensor is pre turbo.
    To me, it seams high.
    What is it supposed to be. How high is safe?
  5. Re: 2.8l tdi (inline 4) (Lt 46) 96 kw, 2001 - performance issues / questions
    Dec 2021
    Stockholm SWEDEN
    Ok, update, and problem solved. So if anyone else find this thread looking for the same answer, here goes.
    I pulled of the turbo, nothing wrong there, replaced the exhaust at the same time.
    The IP fired a little late, so i set it to the earliest recommended setting. Small improvement.
    Tested the injectors, all good. (I can recommend getting an injector tester for anyone who work on old diesels, they can be found online for less than the cost of a single injector.)
    Pressure tested the inter cooler. No leaks.
    Then the intake manifold. A lot of air going somewhere, but did not notice any particular leaks, until i removed the intake. There was a piece of the gasket actually missing, under the intake, at the far back. I made a new gasket, and the problem was gone.
    Lots of power, boost is back, EGT is down.
  1. Audi A6 Allroad engine swap with inline 5 cylinder 2.5tdi
    By chirpy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-08-2015, 02:15 PM
  2. Question A Ton of questions! Upgrades, Performance and General!
    By TwoToneAlex in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-02-2013, 07:30 PM
  3. Question 2001 Passat tdi 130 performance
    By The Scientist in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2011, 10:41 PM
  4. MK4 Golf Tdi 150 performance and upgrades questions?
    By iworld in forum Golf MK4 - 1999 - 2004
    Last Post: 01-01-2009, 08:32 PM
  5. just bought a 04 1.8T and have lots of performance questions.
    By SpiceRedJetta in forum Archive posts
    Last Post: 02-02-2007, 03:17 PM
