Thread: a4 3.0tdi b7 plumes of white smoke
Results 1 to 10 of 15
  1. a4 3.0tdi b7 plumes of white smoke
    Jun 2021
    clydebank
    Hi all,
    So this car has now been off the road for 6 months with various issues. But now the only problem its showing is white smoke and running rough.
    When you first start the car there's a little bit out the exhaust but not much, If I let it sit and idle it sounds really rough and it's shaking a bit but not much smoke.
    After doing my own research everything pointed to injectors so bit the bullet and bought 6 refurbished ones all with good testing reports etc and replaced the copper washers and rubber seals. Which hasn't made any difference.
    If I give it a few revs there's loads of white smoke, and I tried driving it back on forth which made the smoke even worse and running rough.
    The car stinks of diesel.
    Also oil level is bang on max and absolutely no loss of coolant.
    So what else could the problem be???????
  2. Re: a4 3.0tdi b7 plumes of white smoke
    Jun 2021
    clydebank
    Just to add I blocked off the EGR and no change
  3. Re: a4 3.0tdi b7 plumes of white smoke
    1840 Post(s)
    A faulty injector or six, a common problem.
  4. Re: a4 3.0tdi b7 plumes of white smoke
    Jun 2021
    clydebank
    If your right that would mean 12 injectors. The originals that were tested in which 1 was unusable and thus replaced. Then 6 rebuild injectors with glowing reports
  5. Re: a4 3.0tdi b7 plumes of white smoke
    1840 Post(s)
    I don’t trust any of these reconditioned parts, they have cost me more time and money than I care to think about. BUT, that the smoke doesn’t clear when it is revved is odd, no fault codes I assume?
  6. Re: a4 3.0tdi b7 plumes of white smoke
    Jun 2021
    clydebank
    I have a few ATM.
    00819 high pressure sensor g65, SIGNAL TOO LOW
    000258 maf sensor g70, SIGNAL TOO LOW
    000260 maf g70, intermittent dash
    00532 supply voltage b+, SUPPLY VOLTAGE TOO LOW
    INTERESTING ONES
    012597 intake manifold runner control, P3135 LOWER STOP NOT REACHED
    004120 intake manifold runner bank 2, P1018 LOWER LIMIT NOT REACHED
    004673 fuel injector cylinder 5, N88 INTERMITTENT OPEN CIRCUIT P1251
    today I changed the inlet flaps and the rods also cleaned the connection on cylinder 5's plug but haven't had the chance to get the car going again etc got too dark
  7. Re: a4 3.0tdi b7 plumes of white smoke
    1840 Post(s)
    You need all those codes gone to see what to do next, if anything.
  8. Re: a4 3.0tdi b7 plumes of white smoke
    Jun 2021
    clydebank
    LATEST SCAN
    Friday,17,December,2021,13:26:09:02237
    VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
    Data version: 20210903 DS330.0
    Ross-Tech: Home
    VIN: WAUZZZ8EX6A202359 License Plate:
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: WAUZZZ8EX6A202359 Mileage: 105280km-65417miles
    Address 01: Engine Labels: 059-907-401-ASB.clb
    Part No SW: 8E0 910 401 N HW: 8E0 907 401 AL
    Component: 3.0L V6TDI G000SG 0030
    Revision: --H01--- Serial number:
    Coding: 0011911
    Shop #: WSC 06325 000 00000
    VCID: 2A0D0B8B90FFA28BD95-807E
    VINID: 9D196AAAA215A064420020C524999487C7
    3 Faults Found:
    012597 - Intake Manifold Runner Control
    P3135 - 001 - Lower Stop not Reached
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 105282 km
    Time Indication: 0
    Freeze Frame:
    RPM: 882 /min
    Torque: 124.8 Nm
    Speed: 0.0 km/h
    Voltage: 14.44 V
    Duty Cycle: 88.8 %
    Duty Cycle: 88.8 %
    Duty Cycle: 80.9 %
    004120 - Intake Manifold Runner (Bank 2)
    P1018 - 001 - Lower limit not reached
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 105282 km
    Time Indication: 0
    Freeze Frame:
    RPM: 882 /min
    Torque: 124.8 Nm
    Speed: 0.0 km/h
    Voltage: 14.44 V
    Duty Cycle: 88.8 %
    Duty Cycle: 88.8 %
    Duty Cycle: 80.9 %
    005491 - Left Engine Mount Solenoid Valve (N144)
    P1573 - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 105282 km
    Time Indication: 0
    Freeze Frame:
    RPM: 882 /min
    Torque: 124.8 Nm
    Speed: 0.0 km/h
    Voltage: 14.29 V
    Bin. Bits: 0
    Bin. Bits: 0
    Bin. Bits: 0
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes Labels: 8E0-910-517.clb
    Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
    Component: ESP8 quattro H06 0120
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004425
    Shop #: WSC 00861 210 91441
    VCID: 290FF48795F9A993D0F-807C
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BJ
    Component: A4 Klimaautomat 2832
    Coding: 00000
    Shop #: WSC 00861
    VCID: 6A8DCB8B556F628B195-513C
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    07-10 - Signal too Low - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 K
    Component: int. Lastmodul ECE 0704
    Coding: 10001
    Shop #: WSC 06325
    VCID: 3A2D3BCB654F120BA95-4B00
    3 Faults Found:
    02396 - Parking Light Rear Left (M4)
    30-00 - Open or Short to Plus
    01499 - Bulb for High-Beams; Right (M32)
    02736 - Bulb for Tail/Fog Light; Left
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H14 4230
    Revision: 91H14423 Serial number: 0036M0G8VNT9
    Coding: 0034622
    VCID: 3B233ECF6F652B03B23-806E
    Subsystem 1 - Serial number: 6332DRB402D3C9A3Z
    Subsystem 2 - Serial number: 6342DRB402C9911EW
    Subsystem 3 - Serial number: 6352ARB400E1A4EB-
    Subsystem 4 - Serial number: 6362ARB400E1B66BW
    Subsystem 5 - Serial number: 63729RB400ED99A3+
    Subsystem 6 - Serial number: 63829RB400ED9A01V
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0601
    Coding: 02022
    Shop #: WSC 00000
    VCID: 41DF4C27089941D3E8F-4B00
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 951 E HW: 8E0 920 951 E
    Component: KOMBI+WFS 4 H14 0110
    Revision: 0110 Serial number: 00000000000000
    Coding: 0007441
    Shop #: WSC 00667 512 00000
    VCID: 2C010D939A1BBCBB2B9-5184
    Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
    Coding: 0007441
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0804
    Coding: 00001
    Shop #: WSC 00000
    VCID: 6B83CE8F5A957B83623-50F4
    Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
    Part No: 8E0 959 433 CH
    Component: Komfortgerát T3B 4035
    Coding: 07167
    Shop #: WSC 06325
    VCID: 79AFE4C720C9D913E0F-4B00
    Subsystem 1 - Part No: 8E2959802F
    Component: Tõrsteuer.FS BRM 0606
    Subsystem 2 - Part No: 8E2959801F
    Component: Tõrsteuer.BF BRM 0606
    Subsystem 3 - Part No: 8E0959801E
    Component: Tõrsteuer.HL BRM 0606
    Subsystem 4 - Part No: 8E0959802E
    Component: Tõrsteuer.HR BRM 0606
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 D
    Component: concert II GRO 0004
    Coding: 01005
    Shop #: WSC 06325
    VCID: 2809F1838BD3909BCF1-4B3C
    End----(Elapsed Time: 05:13, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
  9. Re: a4 3.0tdi b7 plumes of white smoke
    1840 Post(s)
    None of those engine codes will cause smoke, does it clear fro a while if you rev the engine?
  10. Re: a4 3.0tdi b7 plumes of white smoke
    Jun 2021
    clydebank
    No it gets much worse
  1. A4 3.0TDI 204ps white smoke
    By dollar in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-10-2018, 10:58 PM
  2. Ticking and White Smoke, 2.0TDI
    By daniel3219 in forum Golf MK6 - 2009 - 2013
    Last Post: 04-03-2014, 01:07 PM
  3. Far too much white smoke.
    By 08a6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-03-2013, 07:56 PM
  4. Please Help A4 3.0TDI White smoke
    By skipperd in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-05-2012, 05:46 AM
  5. A6 1.8t white smoke.
    By world-change in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-06-2011, 11:21 AM
