Thread: ATD - VW 1.9 TDI PD - 2 Fault codes : Injector valve Cylinder :Circuit Malfunction & Cylinder 1 Misfire detected, but RESOLVES after shes WARMED UP !
  1. ATD - VW 1.9 TDI PD - 2 Fault codes : Injector valve Cylinder :Circuit Malfunction & Cylinder 1 Misfire detected, but RESOLVES after shes WARMED UP !
    hi
    I had to call the RAC the other day as the car was running rough like say 75% power.
    He very kindly did a diagnostic and the above 2 fault codes came up (DTC 18074 and DTC 16685 respectively)
    After i drove away after 15 mins being idle the car was normal.
    Is this a new injector replacement issue or wire loom issue, or both or something else completely please ?
    Would really appreciate it as need her to drive to Coventry for Xmas.
  2. Re: ATD - VW 1.9 TDI PD - 2 Fault codes : Injector valve Cylinder :Circuit Malfunction & Cylinder 1 Misfire detected, but RESOLVES after shes WARMED U
    1840 Post(s)
    I would go for a new head harness first, it is quite certain this will solve your problem
  1. Please Help Audi S3 Cylinder 4 Misfire Detected
    By Flosmans in forum 2.0T, TSI and TFSI - Engine
    Last Post: 29-05-2021, 05:45 PM
  2. Question fixed 1796 but now misfire cylinder 3 fault code
    By vwnewbie in forum VCDS - Help Requests
    Last Post: 29-07-2018, 06:05 PM
  3. Golf 2003 1.6 Match - Cylinder 4: Misfire Detected
    By blozza in forum Golf MK4 - 1999 - 2004
    Last Post: 28-04-2008, 06:03 PM
  4. Random/Multiple Cylinder Misfire Detected
    By mercaudi40 in forum A8 - S8 - V8
    Last Post: 23-01-2008, 05:46 PM
  5. P0303 Cylinder 3 Misfire Detected
    By bsr1976 in forum Archive posts
    Last Post: 12-10-2006, 06:27 PM
