Thread: Engine Management Light On , 6 Fault Codes
  1. Engine Management Light On , 6 Fault Codes
    Feb 2013
    Uk
    38 Post(s)
    Hi all , this evening started the car after filling with Diesel , drove off and the Engine Management Light came on.
    The car was slow to accelerate and not much power.
    scanned with VCDS when I arrived home and had the following 6 faults.
    Can anyone help me with this please, Car is a 2.0 with 128000 miles, regularly serviced. Many thanks.
    Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
    Part No SW: 03L 906 018 LB HW: 03L 906 018 JL
    Component: R4 2.0l TDI H25 9978
    Revision: 45H25---
    Coding: 0A034012242401080000
    Shop #: WSC 59152 001 1048576
    ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
    ROD: EV_ECM20TDI01103L906018HA.rod
    VCID: 75E180C2D4FC0123E0-8020
    6 Faults Found:
    4806 - EGR System
    P0402 00 [096] - Excessive Flow
    Intermittent - Not Confirmed - Tested Since Memory Clear
    4881 - EGR Valve (N18)
    P1440 00 [032] - Open Circuit
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 6
    Mileage: 205691 km
    Date: 2021.12.03
    Time: 18:00:05
    Engine RPM: 1071.50 /min
    Normed load value: 0.0 %
    Vehicle speed: 52 km/h
    Coolant temperature: 70 °C
    Intake air temperature: 15 °C
    Ambient air pressure: 1020 mbar
    Voltage terminal 30: 14.660 V
    Unlearning counter according OBD: 40
    Air mass: actual value (mg/stroke): 569.2 mg/stroke
    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
    EGR Solen.val.: actual value: 95.75 %
    EGR valve: offset closed: 3.22 %
    Actuator for high pressure EGR: status-Bits 0-7: 0
    Actuator for high pressure EGR: status-Bits 0-7: 35
    Actuator for high pressure EGR: status-Bits 0-7: 55
    High press EGR actuator: actual unconditioned volt val: 737.8 mV
    17403 - Implausible Data Received from Parking Brake Control Module
    U0417 00 [032] - -
    4891 - EGR Valve (N18)
    P0403 00 [032] - Malfunction
    4892 - EGR Valve (N18)
    P0403 00 [036] - Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 206456 km
    Date: 2021.12.14
    Time: 17:26:10
    Engine RPM: 2255.50 /min
    Normed load value: 97.6 %
    Vehicle speed: 33 km/h
    Coolant temperature: 67 °C
    Intake air temperature: 20 °C
    Voltage terminal 30: 13.720 V
    Air mass: actual value (mg/stroke): 1372.0 mg/stroke
    EGR Solen.val.: actual value: 69.38 %
    EGR valve: offset closed: 1.61 %
    High press EGR actuator: actual unconditioned volt val: 1775.0 mV
    5286 - Throttle Position Sensor (G69)
    P0121 00 [096] - Implausible Signal
    Readiness: 0 0 0 0 0
  2. Re: Engine Management Light On , 6 Fault Codes
    134 Post(s)
    2007 Post(s)
    A wild guess would be the EGR valve is faulty.
    1 1 0
  3. Re: Engine Management Light On , 6 Fault Codes
    Feb 2013
    Uk
    38 Post(s)
    Hi Crasher, Many thanks for your response.
  4. Re: Engine Management Light On , 6 Fault Codes
    Feb 2013
    Uk
    38 Post(s)
    started the car this evening, (after leaving it approx 24 hours) - Engine management light is no longer flashing. Acceleration/Power back to normal , can behaving as if nothing has happened.
    Any ideas ?
  5. Re: Engine Management Light On , 6 Fault Codes
    134 Post(s)
    2007 Post(s)
    Completely normal, if you have half a dozen codes that say something is faulty, why ignore them? IF the codes were supoted by a G28 crank speed sensor issue that is different.
  6. Re: Engine Management Light On , 6 Fault Codes
    Feb 2013
    Uk
    38 Post(s)
    The car is Booked in tomorrow with Audi specialist, will let you know the outcome.
  7. Re: Engine Management Light On , 6 Fault Codes
    Feb 2013
    Uk
    38 Post(s)
    New EGR being fitted today/tomorrow - total cost £714.00 , OEM parts used.
  1. Engine management light and glow plug light errors/fault codes
    By zhussain087 in forum Golf MK6 - 2009 - 2013
    Last Post: 26-06-2020, 03:32 PM
  2. Engine management light ...trouble codes??
    By rickirst in forum Bora - 1998 - 2005
    Last Post: 10-02-2009, 06:50 PM
  3. Engine Management light - codes: 17545 & 17705
    By sophdoel in forum Audi A3 - Archive Topics
    Last Post: 08-07-2008, 10:40 AM
  4. engine management fault codes
    By audi-nutz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-03-2008, 07:13 PM
  5. Engine management Light - No fault????
    By koyot in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-12-2007, 09:57 PM
