Thread: After Injector replacement
  1. After Injector replacement
    Dec 2021
    Turkey
    Hello,
    2009 3.0TDI quattro.
    I replaced all six of injectors with brand new Bosch 5000 Km before. I am not sure they were coded/programmed or not at my local mechanic.
    Do I need to do "coding the injectors" now? And is there any VCDS/VAGCOM checks that verify the injectors work normally or not?
    Note: I have no error codes or warning signs btw.
    Thanks in advance.
  2. Re: After Injector replacement
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    You need to check the code on the injectors and confirm they are coded in with VCDS or similar.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: After Injector replacement
    Jul 2008
    Lisburn
    15 Post(s)
    the code tells the ECU what duty time is required for the correct fuel amount - if all the other sensors don't agree on the fuel being burnt, the ecu will compensate - but it can only do this so much.
    So you could "get away" without coding but the car wouldn't be right and could cause issues issues and false fault codes as things are running outside optimal.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  4. Re: After Injector replacement
    Jan 2022
    Swansea
    Interesting. I have to replace an injector on my crafter, so it'll run without adaptation but will need a bit off?
  5. Re: After Injector replacement
    Jul 2008
    Lisburn
    15 Post(s)
    if you are lucky enough that the replacement injector parameters are close enough the original one yes - be prepared for it to run bad enough not to be able to drive - just so you dont get caught out.
    Stewart
  1. Passat B6 Injector Replacement
    By KeithSAFC in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-04-2019, 10:36 AM
  2. Question Injector replacement
    By joedredd in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-08-2016, 01:08 PM
  3. Audi A6 Injector Replacement Help
    By yase12 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-12-2014, 12:13 PM
  4. Please Help Injector replacement
    By Y90USF in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-07-2011, 12:50 PM
  5. Injector replacement.....
    By djl78 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-03-2009, 10:35 PM
