Thread: 2011 Polo full beam not working...
  1. 2011 Polo full beam not working...
    Jan 2008
    Hi! I assume the full beam works via a relay? The flash works but switching to full beam just switches off the dip without the bright lights coming on.
    Anyone know which relay? Thanks
  2. Re: 2011 Polo full beam not working...
    1840 Post(s)
    The dipped lights have a relay but the main beams are direct from the column switch at pin 39 as a white wire and fed on a red wire at pin 38 from the main battery live circuit. If you don't have two blown bulbs (it happens) or two blown fuses (unlikely) then it could be a coupling where the switch output wire divides into two lines and goes to the fuse box at fuses 34 and 36 as a white wire and leaves the fuses as white and green so my expectation would be the column switch.
  3. Re: 2011 Polo full beam not working...
    Jan 2008
    Thanks so much for the information! I'll have a look at the bulbs, and keep my fingers crossed.
  1. Polo Diped Beam Not Working
    By WesleyP in forum Polo - Derby - Lupo - Fox
    Last Post: 22-03-2015, 03:28 PM
  2. Please Help Full Beam Not Working Due To Low Volts
    By rabbie1969 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-07-2011, 10:13 PM
  3. Please Help 2004 Polo Headlamp working but no beam image
    By ozzieosprey in forum Polo - Derby - Lupo - Fox
    Last Post: 12-12-2009, 02:03 PM
  4. Full beam stuck on
    By sportline in forum Golf MK4 - 1999 - 2004
    Last Post: 22-10-2008, 08:20 PM
  5. full beam help needed
    By tatty0001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-11-2007, 01:59 PM
