Thread: 2015 Passat 2.0 Tdi CRL Chuffing and ticking noise
  1. 2015 Passat 2.0 Tdi CRL Chuffing and ticking noise
    Oct 2017
    London
    12 Post(s)
    Any help offered thanks in advance.....
    I have a 2015 2.0 Tdi Passat with a CRL Engine. The car has done 115,000 miles and had the belt done at 110,000 miles.
    Recently the car has developed a chuffing noise on idle and a ticking noise when revved.
    VCDS shows injector 3 reading around 1.2 when started from cold. (All other injectors good) but if i take it for a small drive (during which the injectors all read good) then the bad reading switches to injector 1 which goes to 1.26, inj 2 is -0.7, inj 3 is 0.51 and inj 4 is -1.07
    When injector 1 is bad the chuffing noise at idle disappears but the ticking still stays when revved.
    A compression test shows
    cylinder 1 - 320
    cylinder 2 - 160
    cylinder 3 - 360
    cylinder 4 - 350
    The owner is complaining that the car is using 1 litre of oil every 2 weeks but theres no leaks or smoke from the exhaust. The car drives fine with no loss of power. Any suggestions or ideas would be much appreciated thanks.
  2. Re: 2015 Passat 2.0 Tdi CRL Chuffing and ticking noise
    1836 Post(s)
    Do you known if injector 2 has been replaced? The bolt MUST NOT be reused but people do and this causes leaks or even the injector pair to blow out. If it isn't a compression leak past the injector, your customer has a serious bill looming.
  3. Re: 2015 Passat 2.0 Tdi CRL Chuffing and ticking noise
    Oct 2017
    London
    12 Post(s)
    Thanks crasher. It doesn’t look like any injectors have been replaced. I fear bad news too but the noise sounds similar to how the old pd engines camshafts lobes used to wear. The chuffing is back through the inlet manifold. I forgot to say when you take the oil filter cap off there’s a little bit of blow back there too. No engine faults logged.
  4. Re: 2015 Passat 2.0 Tdi CRL Chuffing and ticking noise
    1836 Post(s)
    Those have roller cams and I haven't had any fail, that low compression is concerning.
  5. Re: 2015 Passat 2.0 Tdi CRL Chuffing and ticking noise
    Oct 2017
    London
    12 Post(s)
    Second hand engine is on the way with a lot less miles. I think it’s the best option with the low compression. Interestingly there are a lot of these selling and a big demand which isn’t good.
  6. Re: 2015 Passat 2.0 Tdi CRL Chuffing and ticking noise
    1836 Post(s)
    I have given up on used engines, boxes and electronics, the grief they have caused me over the years is depressing.
  1. Passat B8 150 2.0 - Puffing/ Chuffing noise on idle.
    By kippermcflipper in forum Passat - B8 Forum - 2015 -
    Last Post: 10-09-2019, 06:55 PM
  2. Question 2012 2.0 Passat bluemotion ticking noise
    By veedubdan in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 11-10-2016, 09:59 AM
  3. Question Ticking noise when taking foot off accelerator pedal. VW Passat B6 2008 2.0 diesel.
    By Lukechambers8 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-08-2016, 03:52 PM
  4. Ticking noise and B pillar noise - TSB and possible solution?
    By dwsugden in forum Golf MK6 - 2009 - 2013
    Last Post: 13-11-2010, 01:23 PM
  5. Please Help A4 2.5tdi v6 chuffing misfiring noise
    By nanndy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-04-2009, 10:24 AM
