Thread: Headlight Aim
  1. Headlight Aim
    Apr 2009
    Surrey
    174 Post(s)
    Was driving the Golf (Life with standard LED headlights) the other evening, I am not the usual driver, and thought the headlight range on dipped beam was pretty poor. Did some searching on the Internet and it seems to be common issue for VWs and how they leave the factory. There is an easy fix. On the top of each headlight is a white plastic screw that needs a 5mm Allen key, circled on photo. I did the recommended 2 full turns anti clockwise and the problem is solved. Hope this helpful to others
  2. Re: Headlight Aim
    Apr 2009
    Surrey
    174 Post(s)
    With the photo
  3. Re: Headlight Aim
    Dec 2021
    Sweden
    What exactly does this do and why does it happen?
  4. Re: Headlight Aim
    Apr 2009
    Surrey
    174 Post(s)
    Quote Originally Posted by Sythaera View Post
    It raises the dip beam height and therefore gives better lit range. Issue is that the cars leave the factory with the beam set too low which limits visibility driving on dipped beam lights on roads without street lights.
  5. Re: Headlight Aim
    Aug 2018
    Gloucester UK
    7 Post(s)
    The lights are dipped for a reason. The alignment should be checked with the proper equipment or it may be too high.
  1. Please Help Headlight Coding Issue after Headlight Swapover
    By DeanoD in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-12-2020, 04:01 PM
  2. Question “Headlight Range Control Defective” after headlight removal
    By spikeheap in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-05-2019, 12:54 AM
  3. Replacing Headlight + Headlight Bulb on A3 Sline Black Edition 2011 Xenons
    By AudiRyda in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-06-2015, 07:32 PM
  4. Headlight
    By A6_JAck in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-12-2010, 09:17 AM
  5. led headlight's
    By big jase in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-12-2009, 10:45 PM
