Thread: Clutch or Engine Mounts
  1. Clutch or Engine Mounts
    Sep 2019
    Coventry uk
    8 Post(s)
    I have a slight problem with my car and was wondering if anyone could point me in the best direction for investigation.
    When the engine is on on from cold in neutral you can feel vibrations from the engine through the gear stick. Vibrations in gear stick are always there even when engine is hot. Car drives fine until the engine gets warm and the bay itself heats up. If I drive 30+ mins and then come to a stop in traffic as I pull away in first the car judders. Once moving it’s fine in all other gears no issues. If I give it lots of revs and then engage the clutch it’s fine. If I also lift the clutch off, allow the car to move under load and then press the accelerator it’s fine.
    No clutch slip at all.
    If I stop for 30-45 mins after a long journey and the drive again it’s ok until the engine bay gets hot again.
    Possible engine mount?
    Where are they and can they be checked with vcds as it appears they have electric connections from online pictures!
    Thanks T
  2. Re: Clutch or Engine Mounts
    1837 Post(s)
    I don’t seem to have the cars VIN to see what it has
  3. Re: Clutch or Engine Mounts
    Sep 2019
    Coventry uk
    8 Post(s)
    snet you a PM, thanks.
  4. Re: Clutch or Engine Mounts
    1837 Post(s)
    The left engine mount is 8R0 199 381 and the right is 8R0 199 381 B, I thought I read you had fitted some by Ridex?
  5. Re: Clutch or Engine Mounts
    Sep 2019
    Coventry uk
    8 Post(s)
    Hi Crasher,
    Thanks. Want to check them before clutch. Not changed or looked at yet.
  6. Re: Clutch or Engine Mounts
    Apr 2016
    London/UK
    23 Post(s)
    Hi
    Could you pls help me with part numbers for my mounts too?
    I will send a DM right now, tyvm
  7. Re: Clutch or Engine Mounts
    1837 Post(s)
    Done
  1. Replies: 1
    Last Post: 13-04-2016, 02:22 PM
  2. Engine mounts
    By alang498 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-10-2015, 08:43 AM
  3. allroad 2.5tdi engine vibrate at tickover/engine mounts?
    By bagpipingandy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-11-2014, 01:42 PM
  4. BXE Engine Mounts
    By TDiBoraSam in forum Jetta MK3 - 2005 - 2013
    Last Post: 24-06-2013, 07:52 PM
  5. A4 Engine support to replace engine mounts
    By JScribner in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2007, 03:57 AM
