Thread: Hard blow from the exhaust (like a fan)
Results 1 to 8 of 8
  1. Angry Hard blow from the exhaust (like a fan)
    Oct 2021
    wa
    Hello everyone, again )
    fighting with a problem, which appeared after changed the egr cooler with an aftermarket, and didn't disappeared after EGR cooler (and valve) replacement with an original and new one.
    Exhaust is really blowing, like some1 turned a fan ON, you can dry clothes...
    Once you add some RPM, it's blowing harder, and i hear it when driving, especially on 4-5-6 gears and uphill...
    The air is coming from the exhaust like from a storm. (It's DRY air, no oil or anything else)... With open back windows on 4000 RPM i hear it like im going to fly.
    It feels like the consumption raised with 0,6-0,8L/100km (but it maybe from the R16 winter wheels)
    IMPORTANT: it is not blowing all the time, it's i think 70%-80% of time. Sometimes it's normal blow, like usually.
    P.S. It is blowing only AIR, no smoke or anything else.
    Video with the problem:
  2. Re: Hard blow from the exhaust (like a fan)
    Sep 2019
    Coventry uk
    8 Post(s)
    No idea on the noise sorry. However is it possible that there is a problem with DPF, exhaust system after all the contamination from the failed EGR unit?
    Check the two DPF pressure sensors to see if they have liquid in the pipes.
    Are all connections tight and no air being drawn in from the engine bay?
  3. Re: Hard blow from the exhaust (like a fan)
    Oct 2021
    wa
    HI Itsrainman.
    The sound appeared in the first 3-5 minutes after i took my car from the shop that changed the EGR cooler with an aftermarket one. (I didn't have this "blowing exhaust" before, im 100% sure, i'm like crazy when it's about my car, looking for new sounds everyday :-D )
    There should be liquid in the pipes? (it is good when they have liquid or not? )
    Don't know if all connections are tight, what i could check by myself i checked and feels like everything is tight...
    Just wondering... can it be the exhaust flap? ))
    sorry, i've just payed twice for the same work (and almost same parts) and still have a problem which i didn't have before, and it's killing me
    I tried to find the problem by myself, but the sound is not constant, for example: if i'm on idle and push the accelerator to 1300-1500-2000-2500 RPM , the exhaust is starting blowing like crazy first ±2 seconds and then stops, even if i keep pushing the accelerator there is no blowing sound) and if i leave it on idle and do the same procedure again, i get the same result (that test was on 0km/h).
    BUT, when i'm driving on 3-4+ gears and pushing the accelerator, it's almost constant (maybe 90% of the times) crazy blowing (with the sound) from the exhaust.
    Funny thing, when i'm in a curbe (accelerating), the sound is not that loud.
  4. Re: Hard blow from the exhaust (like a fan)
    Sep 2019
    Coventry uk
    8 Post(s)
    Take it back to the shop . Ask them to fix it. Was it there before.
  5. Re: Hard blow from the exhaust (like a fan)
    Oct 2021
    wa
    I talked to them (first guys who changed with the aftermarket part) already, and they do not care, they said it's not their fault... like "you put an aftermarket part and there is no warranty for it, even if you replaced than with an original one, the aftermarket part could broke something" and bla bla bla...
    Before i take to the second shop i'm trying to find some info about it, because i feel like i'll hear something like "get back to the shop you changed first part" and so on )
    The best for me is to find something on the net.
    Here is another video with my problem (my video):
  6. Re: Hard blow from the exhaust (like a fan)
    Sep 2019
    Coventry uk
    8 Post(s)
    Sorry no idea but does sound a bit odd!
  7. Re: Hard blow from the exhaust (like a fan)
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    Last egr cooler i swapped in a q5 had little hairline cracks in the steel egr pipes, might be that?
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  8. Re: Hard blow from the exhaust (like a fan)
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    If it is pure air then it must be coming from the boost side of the turbo ( between the turbo/ intercooler/ inlet manifold ) which can leak under pressure when the engine is working harder.
    I'm guessing some of this pipework must have been disturbed while changing the EGR & something has been left loose causing an air leak.
    Could just be that one of the air pipes/ intercooler has developed a split or leak.
    It will need checking carefully to find the leak.
    Someone keep pressing the throttle on/ off & someone else looking/ listening for the leak.
  1. Question B6 Passat DSG Estate 2007 55k - Clouds of black exhaust smoke when accelerating hard in top gear
    By John Whyteleafe in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-01-2018, 07:51 PM
  2. sounds like an exhaust blow but....
    By sx_turbo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-03-2015, 05:03 PM
  3. Am I going to blow something up?
    By flogged_horse in forum Polo - Derby - Lupo - Fox
    Last Post: 16-07-2009, 03:59 PM
  4. Question Blow off Valve
    By ryan_88 in forum Bora - 1998 - 2005
    Last Post: 06-04-2009, 01:46 PM
  5. Have you ever blow anything up?
    Last Post: 22-04-2008, 02:47 AM
