Thread: Allroad automatic gearbox oil change
  1. Allroad automatic gearbox oil change
    Jan 2013
    Skipton UK
    Hi All,
    I'm collecting my 'new' C5 Allroad 2.7T 2001 this weekend that has come in from Japan having done the equivalent of only 46k miles. The car is in unbelievable condition for a 20 year old vehicle but I'm wondering if it would be prudent to have the automatic gearbox oil and filter changed due to its age rather than mileage ? It looks like a job for a specialist from what I've seen on YouTube ! It's driving perfectly so, whilst I don't believe in the 'sealed for life' ethos for any type of oil system, which makes me lean towards changing it, there is also the 'if it ain't broke, don't fix it' school of thought ?
    I'll obviously drive it for a bit to start with but I'd appreciate any thoughts people have on the subject and whether it is as important as it is on say a Range Rover to prolonging the life of the box ?
  2. Re: Allroad automatic gearbox oil change
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    Good luck, this car will keep you busy but you will get rewarded. Transmission oil change in this vehicle is important! The frequency of replacement depends on the form of driving, for example I drive relatively moderately and change transmission oil and filter every 100,000 kilometers. You should also think about changing the differential oil (3).
  3. Re: Allroad automatic gearbox oil change
    1837 Post(s)
    Yes it is a very good idea, those boxes like breaking their internals, especially the reverse drum. The engine in your car can REALLY try your patience, look after the turbo’s with “spool and cool” after a run and 5k oil changes as they are an engine out job.
  4. Re: Allroad automatic gearbox oil change
    Jan 2013
    Skipton UK
    Thanks both for your advice which has definitely swayed my decision to change the gearbox and diff oils sooner rather than later. Engine oil changes at 5k are already part of my maintenance routine for my cars but sounds like that's going to be the least of my worries with this engine ! I'm probably going to now frighten myself reading about the potential problems I can expect....
  1. Allroad radiator (automatic gearbox)
    By Chema.RB in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-07-2017, 09:35 AM
  2. Question Audi A6 C6 Automatic Tiptronic Gearbox Oil Change Question
    By yysnet in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-06-2017, 02:39 PM
  3. Allroad Suspension - Speed Automatic Height Change
    By Valid Username in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-05-2016, 10:33 PM
  4. Automatic tiptronic gearbox A6 allroad 2007
    By kevherb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-10-2012, 01:23 PM
  5. Allroad 2002 2.5 AKE Automatic Cambelt Change after 150K Miles
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-02-2012, 07:10 PM
