Thread: Adblue error (again!)
  1. Adblue error (again!)
    Dec 2010
    stamford
    Hi folks,
    Ive got a 2015 A6 3.0 tdi Quattro.
    my adblue faultlight came on 3 or 4 weeks ago with the 650 miles countdown. We ran Vcds and got the reductant pressure low message.
    On removing the delivery tube and switching on the ignition the fluid duly flowed as expected, but still the warning light remains on after we reconnected it.
    I put it into our local Audi dealership (with the hope of a software fix, as the pump was obviously functioning) but when it got there they found the adblue pipe disconnected, with the adblue over the rear part of the engine. They then diagnosed the pipe connector as being faulty, and said it needed to be replaced before further investigations (if needed) could take place. Trouble is the cost of changing the pipe is £706.
    As the warning came on before the pipe problem, and I drove the car for approx 200 miles before the pipe came off the injector, I think it’s unlikely that the pipe is the problem? I think it might be the pump, but if one adds the cost of a pump replacement to the previous work, it adds up to around £2k.
    ive booked a remap for Monday to attempt to get around this problem, but does anyone have any suggestions as to what would be best to do?
    I don’t want to get into a load more pain with problems from a remap adblue removal, but I can’t see a way forward by keeping the system as is.
    thanks in advance
    Ian
  2. Re: Adblue error (again!)
    1837 Post(s)
    Doing things like removing the reduction system is why the government have proposed heavy handed legislation which will not only criminalise the act of use but the act of sale and installation, see page 11 https://assets.publishing.service.go...nt-version.pdf
  3. Re: Adblue error (again!)
    Dec 2010
    stamford
    Crasher seems to have put the mockers on this post BUT I still need your help and suggestions as to the best way to proceed on this one. I’ve delayed flashing the ecu pending more research.
    thanks forumites
  4. Re: Adblue error (again!)
    1837 Post(s)
    I am currently fighting this on an A5, will report back
  1. Audi A5 Adblue / ECU error?
    By kiranpithwa in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 08-10-2021, 11:40 AM
  2. AdBlue: error
    By wardienet in forum Q7 - 4M Forum - 2016 -
    Last Post: 13-06-2018, 11:58 AM
  3. Q7 adblue error.
    By Spuff in forum New Member Introductions
    Last Post: 05-08-2016, 07:02 PM
  4. Replies: 0
    Last Post: 09-09-2012, 10:42 PM
  5. S3 Haldex error 65535 internal control module memory error?
    By merlin2002 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-06-2009, 09:08 AM
