Thread: Water damaged ECU
  1. Water damaged ECU
    Nov 2021
    New member and I am absolutely desperate and hope that someone can help!!!!!
    I have a 2013 manual VW Passat with a faulty ECU (EDC17). In February this year the car just would not start and it turned out that the ECU was water damaged. Dried it out and put it back in the car and everything was fine for a few months *Then about 5 months ago the engine management light and airbag light came on a stayed on then 2 months ago the coil light started flashing and car kept going into limp mode. When checked it said it was turbo...sent turbo off and they sent it back as it was ok. Garage got a second hand ECU unit with same codes except it was from an automatic. Cloned ECU but cannot get the immobiliser codes from old one to replacement one. They ordered a pin thing that they thought would do the the immobiliser but it hasn't!! The car has been in the garage for 4 weeks and its back to the way it was before (lights on dash, limp mode, turbo code) and garage said they do not know what else to do!!!!*
    I am in the UK and am hoping that someone can help me with this problem or is it a case of I have to take it to VW and have to pay a fortune???*
  2. Re: Water damaged ECU
    Dec 2014
    Bedford
    42 Post(s)
    With hindsight, looks like going to a vw dealer was probably what you should of done from the start. Now even if you do sounds like you might have other engine issues.
    Sent from my SM-G970F using Tapatalk
  3. Re: Water damaged ECU
    1837 Post(s)
    You need to find a VAG specialist that has ODIS with GEKO security access and they can program a new or correct used ECU just as the dealer would be able to.
  4. Re: Water damaged ECU
    Mar 2010
    Derry ireland
    60 Post(s)
    This problem is not beyond a good independant garage person. Can you post up your engine code or reg no the correct no on the rear of the ecu unit
  1. Question Damaged under car
    By Nigma in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-04-2015, 03:31 PM
  2. Audi A4 1996, passenger door damaged and leaking water
    By datsuag in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2014, 03:59 PM
  3. Thule throwbar, module water damaged, new one installed - Not working
    By JonasNJ in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-11-2014, 10:09 PM
  4. 5 day old car already damaged !!!
    By monkeylad in forum Golf MK5 - 2004 - 2009
    Last Post: 04-08-2010, 06:52 PM
  5. Water in footwell- damaged ECU
    By Johnghill in forum Audi A4 - Archive Topics
    Last Post: 07-02-2008, 05:29 AM
