Thread: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Dec 2015
    Blackburn
    Following on from a previous post about a previous issue RE turbo which has been fixed I have had another issue with this car today
    Car has been running perfectly- went to the local shop and on the way engine cut off had a brief message saying LOW OIL PRESSURE STOP ENGINE. cranked the car couple of times and has not started.
    Checked the oil level which seems fine but broke down on a steep hill going downhill so don't know whether oil level is accurate.
    rolled the car onto the pavement and left it there- hopefully with some luck someone will rear-end it as I'm losing my s**t with it. will be going back to the car shortly to get the AA out as had to get back to work,
    Car has done 114k miles, recently had a brand new turbo fitted, new oil feed pipe, new oil filter and was told intercooler pipes etc were cleaned?? could my current issue be related to this or is this something completely different.
    any advice will be greatly appreciated (help @Crasher)
  2. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    I would check the oil on level ground first.....
    check for leaks (especially in areas where work has been done recently).
    after that do a diagnostics and get any fault codes.....you may have a bad sensor etc....
    then also do mechanical checks.....check oil pressure, check condition of oil pump.....is the belt or chain that drives it ok?
    i don’t know the BKD engine so not sure if belt or chain driven.....but guessing it has an oil pump that is driven from the crank....
  3. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Dec 2015
    Blackburn
    Hi thanks for the reply.
    Currently waiting for the AA to come. Visually no oil leaking underneath. Wont be able check oil on flat surface as cannot move it.
    I have plugged it in to software and i got a code
    00003 - control module
    014-defective
    Dont know whether that has anything to do with it
  4. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Dec 2014
    Bedford
    42 Post(s)
    The oil pump drive is made from a hollow metal allen key drive and always rounds off and the first casualty is the turbo.
    Sent from my SM-G970F using Tapatalk
  5. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Dec 2015
    Blackburn
    Had the AA out..well the AA sent a 3rd party Johm Mcadam tech out who said..either oil pressure sensor or oil pump.
    He couldnt tow me as didnt have the towing equipment on his vehicle, which defeats the whole point of coming. Have to wait another 2 hours for another vehicle.
    I hope this doesnt effect my turbo. Its brand new only fitted less than 6weeks ago
  6. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Dec 2014
    Bedford
    42 Post(s)
    A turbo spins at about 250000 revolutions a minute on full boost, about 5000 a second, so if there is no oil pressure then there will be no turbo. The turbo is also a long way from the oil pump ... Turbo's need good air flow , good oil pressure and good quality oil. No1 reason for turbo failure is lack of oil pressure.
  7. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Dec 2014
    Bedford
    42 Post(s)
    Here's the drive that I replaced with a solid chrome vanadium version and had re machined on a VW Passat same engine as yours.
  8. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Dec 2014
    Bedford
    42 Post(s)
    I will take a picture tomorrow of a worn hex drive. I have a fair few lying around the workshop.
  9. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Dec 2015
    Blackburn
    Cars been dropped of to a local garage. AA tech said same thing. Sensor or pump.
    If its worse case scenario i.e pump etc
    What parts need changing and roughly what sort of price am i looking at?
    BTW Where are you based @FLAPPERJACK76
  10. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Dec 2014
    Bedford
    42 Post(s)
    I'm in Bedford bud, sump off, balancer off, gear removed, sent away to engineer, he machines a new key way in the gear, comes back to me with a new oil pump drive in chrome vanadium. Which should last forever. Cost is about £500 all in with a new oil and filter fitted.
  1. Oil Pressure. Stop Engine
    By ak_wf1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-06-2018, 08:00 PM
  2. Please Help stop oil pressure engine off see owners manual
    By artnada in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-02-2012, 01:53 AM
  3. oil pressure stop engine
    By man_utd_99 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-04-2011, 05:55 PM
  4. STOP! engine oil pressure warning
    By del_boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-11-2008, 03:19 PM
  5. Engine Oil Pressure Warning (STOP) - please help
    By Nedx in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-10-2008, 10:41 PM
