Thread: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
Results 11 to 20 of 21
  1. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    108 Post(s)
    1816 Post(s)
    The BKD does not have a balancer system, simple chain driven oil pump
  2. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Dec 2014
    Bedford
    42 Post(s)
    Duh , wrong engine then, my mistake. Oil pressure test, if its too low, either blocked pump or big ends and main bearings usually. Long life servicing?
    Sent from my SM-G970F using Tapatalk
  3. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    108 Post(s)
    1816 Post(s)
    The BKD bottom end (engine generally) is pretty robust, I have seen them take some obscene abuse and be fine
  4. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Dec 2015
    Blackburn
    Thanks for the advice. Garage has checked the car and 1st thing theyve noticed is no fuel going into pump? They had a spare working fuel pump which they are putting in. Surely that cant be it?
    Do you have a link for the oil pump for my engine? @Crasher
  5. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    So the fuel pump has gone? Again not too knowledgable on the BKD engine.....but guessing it has in tank fuel pump then sends it to a vacuum pump?
    Did they say which one it was?
    oil pump part number
    038 115 105 C
    03G 115 105
  6. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    108 Post(s)
    1816 Post(s)
    Yes the BKD is like the BKP there, well just about identical. What do you mean by a link for the oil pump?
  7. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    #17
    Dec 2015
    Blackburn
    @Crasher. Sorry i was asking website link for the the oil pump for my engine.
    Willdudeuk put some part numbers up.
    Are these correct?
    Still waiting on update from the garage about the fuel pump.
  8. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    #18
    108 Post(s)
    1816 Post(s)
    The pump is VAG part number 03G 115 105 and £239.70 from VW, it has been perfectly reliable, never revised and is available from a number of sources, If I did need to replace one I would use the Febi 102507
  9. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    #19
    Dec 2014
    Bedford
    42 Post(s)
    You might have an oil pressure light coming up from continuous cranking. Which is probably because you've got no fuel from pump.
    1 1 0
  10. Re: Golf 2.0 gt tdi bkd 140 dsg mk5- help need again!! Low oil pressure stop engine
    #20
    108 Post(s)
    1816 Post(s)
    That one does throw people, the experienced learn to ignore it but the first time it is a shock.
  1. Oil Pressure. Stop Engine
    By ak_wf1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-06-2018, 08:00 PM
  2. Please Help stop oil pressure engine off see owners manual
    By artnada in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-02-2012, 01:53 AM
  3. oil pressure stop engine
    By man_utd_99 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-04-2011, 05:55 PM
  4. STOP! engine oil pressure warning
    By del_boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-11-2008, 03:19 PM
  5. Engine Oil Pressure Warning (STOP) - please help
    By Nedx in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-10-2008, 10:41 PM
