Thread: emissiin mot failure
  1. emissiin mot failure
    May 2020
    Pontyclun
    Golf 1.9 tdi bxe pd engine.
    It failed the mot on friday with emissions being double what they should be. I fitted a replacement cat pipe and it failed again today as no difference in emissions.
    What the hell?
    What else can i do? i have put diesel cleaner in the tank and plenty of fresh diesel. the car doesn't smoke either.
    There are no modifications to the engine.
  2. Re: emissiin mot failure
    134 Post(s)
    2018 Post(s)
    Make sure the air filter is perfect, even fit a K&N as the more air you get in the less smoke. Check the engine for fault codes and the torsion value to see if it is as close to 0 as possible, not 2 or 3 degrees out.
  1. possible hex key failure?
    By fatpigeon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-05-2019, 06:26 PM
  2. Water Pump Failure / Cam belts failure
    By Fly100 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-06-2014, 11:36 AM
  3. MOT Failure
    By Valiant0007 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-11-2010, 09:09 AM
  4. Golf hit with serious mechanical failure - 1.6TDI Turbo Failure
    By dactel in forum Golf MK6 - 2009 - 2013
    Last Post: 03-02-2010, 07:57 AM
  5. Possible ecu failure? V6 30v 2.8
    By JodyV6 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-11-2007, 04:47 PM
