Thread: Problem with DPF 2.0 BRE
Results 1 to 10 of 14
  1. Problem with DPF 2.0 BRE
    Nov 2021
    Corby
    Hello
    Problem with dpf every week clogged dpf auto in safe mode,
    dpf disassembled soaked in cleaning chemistry then rinsing with a pressure washer, a week of peace and renewal used foams for cleaning dpf the same effect a week of calm and clogged again,
    a bit of history of the car 2.0tdi BRE engine, the head was changed to a regenerated one, the old one had cracks between the valves and the spark plug, after the change everything was ok for two days and problems with the dpf began,
    I did the heads myself, I put everything together according to the book, but to be sure I took the car to the mechanic, they checked the timing again, they set the injectors again, but the problem did not disappear, and now the question is because when I was buying the head gasket, they advised me in the store that it is better to put it thicker than it was that it will be better for the engine etc. The question is whether a thicker gasket can cause problems with t dpf, before replacing the head I had no problems with the dpf. The pressure difference sensor on the dpf was also replaced.
    New dpf fitted last week and the same clogged after a week,
    Advise me please because I already lack ideas and patience for this car
    Regards Bartosz
  2. Re: Problem with DPF 2.0 BRE
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    Its unlikely to be the head gasket, how many miles has it done? Could be all sorts though sensors egr system is that working correctly? Is the turbo ok? Any fault codes?
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: Problem with DPF 2.0 BRE
    Nov 2021
    Corby
    So at the moment no fault codes just light on dash. it has done 119000, Egr I was testing it with vcds and it's working, I disconnect as well tube which going out from egr cooler to egr valve start the engine and smoke was going out from pipe so am assuming cooler is not clogged,
    DPF pressure sensor was changed and dpf temperature sensor as well,
    I'm Thinking about injectors may by them causing that problem??
  4. Re: Problem with DPF 2.0 BRE
    May 2012
    Everywhere
    308 Post(s)
    BRE , subject to the 77mm planned obsolescence device .
  5. Re: Problem with DPF 2.0 BRE
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    " I disconnect as well tube which going out from egr cooler to egr valve start the engine and smoke was going out from pipe so am assuming cooler is not clogged, "
    But does the EGR valve close completely when
    commanded by the ECU.
    If it is stuck partially open, the DPF won't be able to regenerate.
  6. Re: Problem with DPF 2.0 BRE
    1840 Post(s)
    Quote Originally Posted by barteekb View Post
    That is technically not possible (with some odd exceptions like I had this week) so which code reader are you using?
  7. Re: Problem with DPF 2.0 BRE
    Nov 2021
    Corby
    EGR yes I have checked it By VCDS and its open and closed completely when tested.
    I'm using VCDS version i think it is 21.1 and I have as well VagCanPro. About falut codes It showing DPF sign on dash meaning regeneration is started, before with old dpf it was showing P2002 diesel particulate filter efficiency below threshold
  8. Re: Problem with DPF 2.0 BRE
    1840 Post(s)
    In my experience P2002 means the DPF is blocked and will not forced regen unless you cheat which is dangerous.
  9. Re: Problem with DPF 2.0 BRE
    Nov 2021
    Corby
    Yes I know that but I have changed DPF for brand new and after a week time it shows me light on dash. I don't thing it is blocked after a week time.
  10. Re: Problem with DPF 2.0 BRE
    1840 Post(s)
    Which make, B&M?
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Sat Nav problem? Or user problem? Can't select postcode entry.
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-09-2012, 10:41 AM
  3. Puzzling coolant temperature problem (not just a sender problem)
    By bartonthesparta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 06:58 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
