Thread: Problem with DPF 2.0 BRE
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Problem with DPF 2.0 BRE
    Nov 2021
    Corby
    Not sure about brand but it was cheaper one
  2. Re: Problem with DPF 2.0 BRE
    1840 Post(s)
    Well we used the B&M Premium units and after three under warranty, gave up and repaired the damaged thread on the original (which thankfully the scrap man had not taken) had DPF Clean Team clean it, did a regen and it has been fine for the last four years, we flatly refuse to fit aftermarket DPF's no matter what.
  3. Re: Problem with DPF 2.0 BRE
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    In your first post you stated " a bit of history of the car 2.0tdi BRE engine, the head was changed to a regenerated one ".
    Did the new head come ready to install or did you transfer your original parts to a refurbished head?
    Reason I ask is that I understand the camshaft for a DPF engine is different to a non DPF engine.
    If the wrong camshaft is fitted it won't be able to regen the DPF.
  4. Re: Problem with DPF 2.0 BRE
    Nov 2021
    Corby
    Yes I bought new head ready to fit, I was thinking about camshaft but do not have idea how to check them,
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Sat Nav problem? Or user problem? Can't select postcode entry.
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-09-2012, 10:41 AM
  3. Puzzling coolant temperature problem (not just a sender problem)
    By bartonthesparta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 06:58 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
