Thread: A6 C7 2.0 tdi 190 hp, check engine light on
  1. Angry A6 C7 2.0 tdi 190 hp, check engine light on
    Oct 2021
    wa
    Hello
    Help me please with a problem.
    Car: A6 c7 Avant 2.0 tdi 190 hp. (CNHA)
    Problem:
    After a bad gas station (filled with diesel 55), next day i found a bad smell from the exhaust and very little GRAY smoke... AND check engine light on (not flashing). (NO POWER LOSE, and very stable engine rotations)
    >>> After 100 miles of driving i went to the service and they connected a tester to check for errors...
    It was only 1 error on the DPF filter, it wasn't full (regenerations are every 300-400 miles) but they said it will need to be manually cleaned, they told me to come next day. And i went for a drive for 200 miles)
    >>> Next day i came to the service and before starting DPF cleaning they connected a tester once again, and surprise, there were NO ERROR on DPF filter, but there was an error on AdBlue PUMP...
    They told me to change the adblue pump, i said no and went home...
    >>> I burned all the fuel from the bad gas station and filled with (what i think it's a good station, but with diesel 51 octane), I changed AIR filter and Fuel filter, drove 50-60 miles and Check engine light was GONE... I was super happy... Drove about 150 miles and check engine light was on again...
    >>> Went back to the service and checked for errors, surprise, again the error on DPF filter...
    >>> We started a FORCED regeneration and deleted the error, bad smell from the exhaust was gone and i was super happy...
    >>> Next day again check engine light on
    Is there a possibility that it was the oxygen sensor? Can it be broken without showing an error on it?
    No one from the service know what it can be.
    Please help
  2. Re: A6 C7 2.0 tdi 190 hp, check engine light on
    Oct 2021
    wa
    Hi everyone. Went today for another check for errors and i've got the error P200200, can anybody help please? thanks!
  3. Re: A6 C7 2.0 tdi 190 hp, check engine light on
    1841 Post(s)
    The DPF is blocked and needs to be removed for proper off the car cleaning
    18434 (P2002) - Particle Filter Bank 1: Malfunction
  4. Re: A6 C7 2.0 tdi 190 hp, check engine light on
    Oct 2021
    wa
    Hi Crasher. Thank you for your answer!
    They said i have to change the EGR and it will be fine (just talked with them).
    But i'm not sure, thats why i would like to know your opinion...
    (because of bad experience in the past, of changing a lot of things which didn't need to be changed)
  5. Re: A6 C7 2.0 tdi 190 hp, check engine light on
    1841 Post(s)
    The fault code P2002 has nothing to do with the EGR valve. Could I have the VIN?
  6. Re: A6 C7 2.0 tdi 190 hp, check engine light on
    Oct 2021
    wa
    Yeah of course, VIN: WAUZZZ4G0GN039688
    They told me to change the EGR cooler
  7. Re: A6 C7 2.0 tdi 190 hp, check engine light on
    1841 Post(s)
    The EGR cooler is mounted to the SCR/DPF assembly but I can't see why it would need replacing if there is no fault code. The SCR/DFP used on yours has been superseded but is around €2500 so we would have it professionally cleaned, I don't know if you can get that done in Germany?
  8. Re: A6 C7 2.0 tdi 190 hp, check engine light on
    Oct 2021
    wa
    Thanks for your answer
    I have regenerations every 400-700km (around 400km when 50%+ city driving, and 700+ if highway), how i know there should be a regeneration every 100-200km if the DPF is full...
    But i hope i'll get it done with the EGR cooler change.
    I'll be back with the result in a few days
  1. Question Check engine light on and engine vibrating when ignition turned off
    By sapstar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-08-2021, 09:50 AM
  2. Question no crank, glow-plug light blinking and check engine light on.
    By rayrowie in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 26-03-2016, 02:17 PM
  3. Attention Check engine light (MIL, CEL light) not working
    By minty2013 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2013, 08:57 AM
  4. audi low oil pressure light,check engine light
    By redviper131 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-05-2010, 06:51 PM
  5. Please Help 52 reg 1.4 16v Lupo SE has EPC light, Engine check light and stiff brake pedal
    By robbig in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2008, 10:45 PM
