Thread: Convenience control module
  1. Convenience control module
    New Forest
    80 Post(s)
    Owing to water ingress - due to drains for sunroof and the ones in the plenum chamber, being blocked - I require a new module.
    The one as fitted, is
    8W0 907 064 AD
    and the Audi UK supplied replacement, is
    AW1 907 064 BH
    However, it seems impossible to code this module, which according to Audi UK may be for a number of reasons.
    Does anybody know if that is the correct module to replace the original?
    Sent from my SM-G965F using Tapatalk
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  2. Re: Convenience control module
    1841 Post(s)
    I need your reg by PM or post the VIN.
  3. Re: Convenience control module
    Aug 2020
    9 Post(s)
    I'm concerned I could be inadvertently clogging up my plenum chamber drain holes (lots of trees in the drive). Is there a link to a guide online showing how to check and keep these unclogged?
    Thanks,
  4. Re: Convenience control module
    New Forest
    80 Post(s)
    Quote Originally Posted by ckq7 View Post
    Thanks,
    Don't know if there's anything online but the independent VAG garage I used, removed the rear wheels, to clear the sunroof drains and had to remove the covers - nearest the windscreen, under the bonnet - to clear the plenum chamber drains.
    5 years of oak leaves, had turned to a claggy mush, blocking it all.
  5. Re: Convenience control module
    New Forest
    80 Post(s)
    Thanks Crasher. It's been mostly sorted now. Just a coding problem with the panoramic sunroof (neither glass nor blind, will slide back more than halfway and the buttons have to be held, as if there's a roll-back issue) and an error with the parking brake.
    I'll have to get them to look at the coding again.
    I had to pay three times for a DIS to Audi, in order for the coding to complete. It appears the new module, had a firmware/software update, of release 9, which was then reverted back to release 7, in order to be compatible with the other modules in my car.
    Obviously, I want the sunroof to operate correctly, so that is going to have to be sorted.
  6. Re: Convenience control module
    Sep 2018
    Leicester
    6 Post(s)
    Quote Originally Posted by ragebe View Post
    Hi Regebe,
    Can you share pictures/instructions of what panel needs to come off to check/remove clean drains? Thanks
  7. Re: Convenience control module
    New Forest
    80 Post(s)
    Quote Originally Posted by Q717 View Post
    Hi Regebe,
    I can't I'm afraid, as I didn't do the work personally.
  1. Please Help Golf Mk4 1.9TDI 2003 - Convenience Control Module (CCM) - Left indicators stay on??
    By mumutley in forum Golf MK4 - 1999 - 2004
    Last Post: 10-07-2020, 10:48 AM
  2. Please Help audi a6 c5 2003 comfort/convenience control module problem. help needed.
    By rokis in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-03-2015, 01:50 PM
  3. Question Convenience Module
    By akeem in forum Audi A3 - Archive Topics
    Last Post: 19-01-2009, 12:38 AM
  4. s/hand convenience control module's
    By maxthedoggy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-10-2008, 03:35 PM
  5. Replies: 7
    Last Post: 07-04-2008, 09:00 PM
