Thread: Judder first gear / reverse on biting point on NEW clutch and flywheel
  1. Judder first gear / reverse on biting point on NEW clutch and flywheel
    Nov 2021
    Stevenage
    Hi guys, I have a VW Passat 2009 CBAB which I changed clutch kit and flywheel from Sachs today at a local mechanic. My car is 178k and apparently never changed clutch or flywheel.
    After he finished with work, I did go for a test drive, at some point I did a front bay park then reversed a little bit to adjust parking. As soon as I lifted my foot enough for the biting point of the new clutch, I immediately noticed judder, both in first gear or reverse.
    He claimed to be the parts as he apparently followed all the correct steps and procedures and it may "settle" after using it a bit, but my problem is, if this judder happens when parts are new, when flywheel will start being worn, then will it probably be considerably worse?
    Can you please let me know if you have experienced anything like this, and if you could tell me the possible cause of this issue, it is very frustrating when I spent over £900 for doing gearbox oil and couple of bad bushes as well.
    Many thanks! Drive safe!
  2. Re: Judder first gear / reverse on biting point on NEW clutch and flywheel
    108 Post(s)
    1816 Post(s)
    A full Sachs kit should not judder, we are doing the same job tomorrow on a Sharan be on this we are using LUK which is another OE supplier like Sachs. For it to jibber something is definitely wrong but it could be the subframe gearbox toque reaction mount has failed as can happen when it is dismantled.
  3. Re: Judder first gear / reverse on biting point on NEW clutch and flywheel
    Oct 2017
    London
    12 Post(s)
    178k on an original clutch? That’s good going the most I ever seen was around 140k. It’s very unlikely that the judder will go away. It has all the hallmarks of a cheap single mass conversion. Do you trust your mechanic ok? Where did you buy the kit from? Please don’t say techniclutch off eBay as they have an alleged tendency to fake popular clutch manufacturers products and mix their own cheap rubbish in with the real parts.
  1. Please Help Clutch Judder At Biting Point.....? Not Sure What It Is
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-01-2014, 11:44 AM
  2. Low biting point
    By spicepradeep in forum Golf MK4 - 1999 - 2004
    Last Post: 24-04-2011, 08:35 PM
  3. High biting point
    By liviboy in forum Golf MK5 - 2004 - 2009
    Last Post: 17-10-2010, 08:41 AM
  4. Clutch biting point 1.8T AUM
    By ad1966 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-02-2009, 03:28 PM
  5. Clutch biting point too low - A3
    By SimonPopp in forum Archive posts
    Last Post: 14-10-2007, 05:18 PM
