Thread: MK7 Golf water ingress locations
  1. MK7 Golf water ingress locations
    Apr 2018
    N.Ireland
    9 Post(s)
    Over the past week i have been checking all the water leak locations related to the mk7 golf with or without sunroof and thought i might as well consolidate for the inevitable happening to someone else in future.
    Body Vent & Tail lights !! SOLVED !! The other other other VW Golf Mk7 rain water leak!! Water ingress - YouTube
    Sunroof frame cracks How to fix a leaking MK7 GTI sunroof. : GolfGTI
    Sunroof drain pipes definitive guide to repair panoramic sunroof leaks. | VW Vortex - Volkswagen Forum
    How to clean drain pipes 2018 VW GTI SE Ep.275: Cleaning Your Sunroof Drains - YouTube
    Door Speaker seals Water Leaking onto Carpet of Rear Door - Volkswagen VW Golf Mk7 MKVII Leaking Through Speaker Seals - YouTube
    please add more if you know of any
  2. Re: MK7 Golf water ingress locations
    1840 Post(s)
    Body vents behind the bumper and rear door speakers are the most common.
  3. Re: MK7 Golf water ingress locations
    Apr 2024
    south wales
    Hi. I have a water leak on my mk7 golf. Replaced rear speakers.. Rear light seals seem OK when boot is closed, but when I pour water down towards the light with the boot open, there is slight water ingression. Boot floor was slightly damp. It has been suggested to look at scuttle panel/pollen filter aperture seal under the wiper mechanism. For the amount of water (7 litres) that I initially took out it has a serious leak somewhere !? Sunroof drains appear to drain as they should (they have been cleaned - front only. can't manage the rear at the moment. Any more possible points of water ingression ? Has anyone else owned GF66XUU ?
  1. Golf Mk iv 2000W Water Ingress
    By Peter Sproston in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2011, 06:26 PM
  2. MK5 Golf - water ingress through top of windscreen ?
    By IPreferMyJag in forum Golf MK5 - 2004 - 2009
    Last Post: 06-12-2009, 10:03 AM
  3. Question Water ingress driver side door 3door golf MK4
    By Rubyturner in forum Golf MK4 - 1999 - 2004
    Last Post: 03-09-2009, 05:47 PM
  4. Golf water ingress problem
    By Adrian Wood in forum New Member Introductions
    Last Post: 09-08-2009, 11:11 PM
  5. Water ingress in Boot on Golf Mk 4
    By tobert in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-05-2007, 12:11 PM
