Thread: 1.6TDI P0299 Boost Pressure Regulation
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: 1.6TDI P0299 Boost Pressure Regulation
    #11
    Dec 2016
    Somerset
    Cool, thought that might be the case re thermostat.
    Yeah still getting the same 2 error codes as before :-/
  2. Re: 1.6TDI P0299 Boost Pressure Regulation
    #12
    1837 Post(s)
    You need to check the setup of the actuator, it may have been replaced and incorrectly set up. You will need a special spanner and socket to make adjustsmtns and a vacuum pump with gauge to perform the tests
  3. Re: 1.6TDI P0299 Boost Pressure Regulation
    #13
    Dec 2016
    Somerset
    Thanks for all the info crusher! I do quite fancy trying to take that on, however I think that's going to be a little advanced for me, plus don't have a vacuum pump either so may have to accept defeat and take it to a garage
  1. 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    By s1paulj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-08-2017, 08:33 PM
  2. Please Help Boost Pressure Regulation
    By Mischiu in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2016, 12:41 PM
  3. Replies: 0
    Last Post: 27-05-2015, 04:21 PM
  4. Replies: 1
    Last Post: 06-06-2014, 09:50 AM
  5. Boost pressure regulation!
    By s_line_junkie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-05-2009, 10:18 AM
