Thread: VW Golf MK5 2.0 GT TDI (BKD) Camshaft position sensor/VCDS torsion value
  1. VW Golf MK5 2.0 GT TDI (BKD) Camshaft position sensor/VCDS torsion value
    Mar 2018
    Liverpool, UK
    Hi all,
    I've recently found my camshaf sensor was producing a no signal/implausible signal on a fault code scan, I had an extended crank on start up and it would start hard. So I've purchased a new sensor from Euro Car Parts (Haas Camshaft position sensor product code
    41944090) and fitted with a new belt etc.
    I've then used VCDS to ensure my timing is accruate, on doing this I found that the fuel was at 1.2l/hr so adjusted to 0.4l/hr . However, despite fitting a new sensor to the camshaft, the torsion value reads 0.0kw until the car's RPM is lifted then it gives values all over the shot (-60 to +45). Once warm and settled it will stay on 0.0 but then will jump between -20 to + 20. Car runs fine, any ideas?
  2. Re: VW Golf MK5 2.0 GT TDI (BKD) Camshaft position sensor/VCDS torsion value
    Mar 2018
    Liverpool, UK
    Here is said pics from VCDS
  3. Re: VW Golf MK5 2.0 GT TDI (BKD) Camshaft position sensor/VCDS torsion value
    108 Post(s)
    1816 Post(s)
    So the torsion value jumps at idle?
  4. Re: VW Golf MK5 2.0 GT TDI (BKD) Camshaft position sensor/VCDS torsion value
    Mar 2018
    Liverpool, UK
    Not whilst warming up, it stays at 0.0. When the coolant temp got to 75-80c it jumped to both negative and positive numbers.
    When raising revs it also jumps momentarily, and when letting revs drop it does it too.
    I should add despite the new sensor the car is still throwing the implausible signal code
  5. Re: VW Golf MK5 2.0 GT TDI (BKD) Camshaft position sensor/VCDS torsion value
    108 Post(s)
    1816 Post(s)
    Did you use locking tools?
  6. Re: VW Golf MK5 2.0 GT TDI (BKD) Camshaft position sensor/VCDS torsion value
    Mar 2018
    Liverpool, UK
    Yeah, could't get them to be an exact fit in the cams when the crank lock was on and in TDC though. Are you thinking it's way out which is why it's throwing bizzare numbers?
  7. Re: VW Golf MK5 2.0 GT TDI (BKD) Camshaft position sensor/VCDS torsion value
    108 Post(s)
    1816 Post(s)
    It has to be so precise; even a tiny way out and it will not be happy.
  8. Re: VW Golf MK5 2.0 GT TDI (BKD) Camshaft position sensor/VCDS torsion value
    Oct 2017
    London
    12 Post(s)
    I’ve seen bizarre numbers on cheap eBay cam sensors and also when the cam pulley tabs get damaged.
  1. Golf Match TDI 105 Camshaft Position Sensor issue
    By Dermottc in forum Golf MK5 - 2004 - 2009
    Last Post: 06-09-2016, 03:34 PM
  2. Camshaft position sensor / sender (G40 Hall sensor) replacement Audi A6 2.0 BRE
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 02:26 PM
  3. Question Camshaft position sensor
    By paul.c in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-05-2012, 08:36 PM
  4. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  5. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
