Thread: Overboost fault code but n75 and turbo vanes seem ok
  1. Angry Overboost fault code but n75 and turbo vanes seem ok
    Oct 2016
    Bury St Edmunds
    I have a 2007 passat 2.0l diesel with a bkp engine and am getting an overboost code and limp home particularly when towing up hill. Aftrer reading up on it I thought it was sticking torbo vanes but they are moving ok. How can I test the manifold pressure sensor? Has anyone got any other ideas? Can the actuator adjustment go out or need resetting? Thanks for any help you can give
  2. Re: Overboost fault code but n75 and turbo vanes seem ok
    1840 Post(s)
    Even if the vanes move they can stick due to temperature and air speed changes, 99% of the time overboost is a sticking vanes
  3. Re: Overboost fault code but n75 and turbo vanes seem ok
    Mar 2010
    Derry ireland
    60 Post(s)
    The turbo pressure control solenoid & the exhaust gas cooler solenoid are inter connected on this bkp engine code. I would be checking you vac reading at the turbo pressure control which should read approx 26/27 inhg
  4. Re: Overboost fault code but n75 and turbo vanes seem ok
    Oct 2016
    Bury St Edmunds
    Thank you for your help on that.
  5. Re: Overboost fault code but n75 and turbo vanes seem ok
    Oct 2016
    Bury St Edmunds
    Thanks for your help and information.
  1. Turbo vanes gone, what now?
    By Luffers in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-12-2014, 06:50 PM
  2. stick turbo vanes
    By boidy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-04-2009, 09:51 PM
  3. sticky turbo vanes
    By bigplum in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-11-2008, 11:39 PM
  4. turbo vanes.
    By davetdiredi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2008, 07:39 PM
