Thread: P2002 Error Code - 2.0TDI Ultra
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. P2002 Error Code - 2.0TDI Ultra
    Sep 2019
    Coventry uk
    8 Post(s)
    Hello All, so earlier this week my car threw the engine management light which did not go out. Car drove fine and has good MPG at around 780 miles to a tank of diesel. Way better than the last A6 I had with the older engine. I read the code and reset with VCDS and this morning the engine managment light came on again. I have not had the car long but from a private seller so no comeback . Car has been driven 3000 miles since purchase so perhaps I am unlucky.
    Any way VCDS log is below:
    1 Fault Found
    19226 - Particulate Trap Bank 1
    P2002 00 [232] - Efficiency Below Threshold
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 126
    Mileage: 84835 km
    Date: 2021.09.28
    Time: 07:46:00
    Engine RPM: 1652.00 /min
    Normed load value: 47.8 %
    Vehicle speed: 97 km/h
    Coolant temperature: 89 °C
    Intake air temperature: 71 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 14.500 V
    Unlearning counter according OBD: 40
    Exhaust mass flow of low-pressure EGR: calculated: 3.007
    Differential pressure ratio: low-pressure EGR: 22.9 kg/h
    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 25.5 hPa
    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 26.2 hPa
    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 73.27 %
    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 42.42 %
    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 24.8 hPa
    Readiness: 1 1 0 0 0
    Any ideas?
  2. Re: P2002 Error Code - 2.0TDI Ultra
    1840 Post(s)
    I would fit and calibrate a new genuine pressure sensor and then carry out a forced regeneration.
  3. Re: P2002 Error Code - 2.0TDI Ultra
    Sep 2019
    Coventry uk
    8 Post(s)
    Cheers Crasher
    Would you happen to know the part number. I suspect it’s a Bosch sensor so can I purchase one from GSF if the manufacture part number is the same?
    T
  4. Re: P2002 Error Code - 2.0TDI Ultra
    1840 Post(s)
    No, a genuine sensor from TPS or Audi, from painful experience I will use nothing else. It is VIN specific.
  5. Re: P2002 Error Code - 2.0TDI Ultra
    Sep 2019
    Coventry uk
    8 Post(s)
    Ok cheers.
  6. Re: P2002 Error Code - 2.0TDI Ultra
    Sep 2019
    Coventry uk
    8 Post(s)
    Ok cheers. Do you the sensor number?
  7. Re: P2002 Error Code - 2.0TDI Ultra
    1840 Post(s)
    I don’t have your reg or VIN
  8. Re: P2002 Error Code - 2.0TDI Ultra
    1840 Post(s)
    03L 906 051 D £81.29 retail inc VAT.
  9. Re: P2002 Error Code - 2.0TDI Ultra
    Sep 2019
    Coventry uk
    8 Post(s)
    You r a star. Will order tomorrow and see how it goes. Thanks as always.
  10. Re: P2002 Error Code - 2.0TDI Ultra
    Sep 2019
    Coventry uk
    8 Post(s)
    Hi Crasher, quick question. Is that both pressure sensors?
  1. Audi A4 B7 2.0 TDI BPW P2002 Code
    By internautul in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-07-2021, 01:44 PM
  2. DPF issues - soot level 6.63 error p2002 p2463 05188 05189
    By Heathy in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-12-2020, 09:52 PM
  3. P0471 Error Code - Exhaust Pressure Sensor? - A4 B7 2.0Tdi 140bhp Cabriolet
    By davidmbell in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-09-2019, 09:17 PM
  4. P2002, p0544 error codes
    By aj1soad in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 05-05-2019, 11:51 AM
  5. Please Help Error code first one P2002
    By teddy2k5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-06-2014, 12:12 PM
