Thread: P2002 Error Code - 2.0TDI Ultra
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. Re: P2002 Error Code - 2.0TDI Ultra
    #21
    Sep 2019
    Coventry uk
    8 Post(s)
    Might end up coming to you Crasher, they don’t want to clean invade it does not work and are then liable for additional labour
  2. Re: P2002 Error Code - 2.0TDI Ultra
    #22
    Oct 2021
    wa
    Itsrainman, hi mate!
    I have the same error as yours (P200200) and i was told to change the EGR cooler.. changed and the error is still there.. No power lose, but it happened after i went to a gas station and filled with "bad" fuel (even if it was diesel 55 and most expensive in my city), the next day i've got engine check light and 4 weeks can't get it done)
    I'm just sharing my experience with you, because i was told by the official dealer to change the EGR cooler and they were wrong. I have the same 14g in DPF.
    Can i ask you please... do you still have this error (p200200) and check engine light on?
  3. Re: P2002 Error Code - 2.0TDI Ultra
    #23
    Sep 2019
    Coventry uk
    8 Post(s)
    Error was reset after the change of both sensors and a forced DPF regen. I have only done about 10 miles since then so to be honest I have no idea if the fix is permanent.
    I got the impression that because the sensors maybe faulty the actual DPF loading was being misread. The garage used parts from TPS so Audi parts and then recalibrate and then drive the car while monitoring the soot value until it stabilises and then run the DPF regen routine and again monitor the soot loading until it drops and stabilises. Fingers crossed. I had the older engine in my previous A6 and the EGR cooler was a lot easier to access than on the Ultra Engine. I’m a pretty competent mechanical engineer but just don’t fancy doing it on the drive over winter . Getting a petrol car next time
  4. Re: P2002 Error Code - 2.0TDI Ultra
    #24
    1840 Post(s)
    Quote Originally Posted by Itsrainman View Post
  1. Audi A4 B7 2.0 TDI BPW P2002 Code
    By internautul in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-07-2021, 01:44 PM
  2. DPF issues - soot level 6.63 error p2002 p2463 05188 05189
    By Heathy in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-12-2020, 09:52 PM
  3. P0471 Error Code - Exhaust Pressure Sensor? - A4 B7 2.0Tdi 140bhp Cabriolet
    By davidmbell in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-09-2019, 09:17 PM
  4. P2002, p0544 error codes
    By aj1soad in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 05-05-2019, 11:51 AM
  5. Please Help Error code first one P2002
    By teddy2k5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-06-2014, 12:12 PM
