Thread: Third brake light always on even if car is switched off audi A3 2005
  1. Third brake light always on even if car is switched off audi A3 2005
    Jan 2011
    birmingham
    Morning,
    I have recently noticed that my third brake light is on even thought the car is off and parked up, however it doesnt seem to do this always. It seems to be on in more damp conditions.Any thoughts as to where to start looking with this one,Any feedback will be greatly appreciated
  2. Re: Third brake light always on even if car is switched off audi A3 2005
    1841 Post(s)
    Does it have a tow bar?
  3. Re: Third brake light always on even if car is switched off audi A3 2005
    Jan 2011
    birmingham
    no tow bar, but if i disconnect the battery for 10 mins or so the third brake light goes off and stays off, but then at some point it comes on usually overnight though not always.Damp wet conditions seem to be a trigger for it .
  4. Re: Third brake light always on even if car is switched off audi A3 2005
    1841 Post(s)
    I can’t consult a wiring diagram but I am confused why one of the other brake lights don’t come on, I can’t remember how they are wired up from the BCM, I need ELSA at home!
  5. Re: Third brake light always on even if car is switched off audi A3 2005
    Jan 2011
    birmingham
    once again thanks for your input, but only the third brakelight stays on. The other work when the pedal is pressed but the third stays on all the time
  1. 2005 (55) A6 Avant intermitent high level brake light
    By Steve-T in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-03-2015, 12:30 AM
  2. 2005 B7 2.0TDI: Brake warning light on start up
    By Marty 55 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-09-2014, 09:16 PM
  3. Please Help Fan no longer runs after engine switched off on 2005 Golf Plus 1.9 TDI
    By dorismax22 in forum Golf MK5 - 2004 - 2009
    Last Post: 11-12-2012, 01:41 PM
  4. 2001-2005 A4 - Engine Check Light - Brake Boost - System too lean - System too Rich
    By A4nutter in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 14-10-2009, 09:45 PM
  5. brake and abs warning lights after xenons switched on
    By andy5468 in forum Audi A4 - Archive Topics
    Last Post: 25-01-2008, 07:53 PM
